Zabbix server queue has increased significantly.
  • VeeEnDee
    • Jul 2022
    Hey all,
    After update of zabbix server from 5.4 to 6.0.6 version Zabbix server queue has increased from 0 to average 400.
    On attached screenshots we can see situation before update (first) and after update (second) for "Zabbix queue" item with key "zabbix[queue]".
    No configuration change was performed
    No errors in logs for zabbix server on database
    Overall situation is the same exept for zabbix version changed.
    Has something changed in the way how zabbix queue check is performed?
    How does that parameter affects zabbix performance?
    Should we do somthing about that queue, or momentum zabbix queue (<5 sec ) is OK?
    Environment:
    Zabbix server 6.0.6
    CentOS Linux 8
    Postgresql 13 + timescaledb extension 2.3.0
    2 zabbix proxies:
    version 6.0.6
    Rocky Linux 8.5
    10.5.13-MariaDB
  • Markku
    • Sep 2018
    • 1784
    What do you find in the queue? https://www.zabbix.com/documentation...stration/queue
    Markku
    • VeeEnDee
      • Jul 2022
      Markku
      Hi Markku,
      Thanks for your reply.
      You can find screens of the queue attached
