[From Upgrade 6.2] - Lost data history
  • Coll77
    • Dec 2020
    From upgrade to zabbix 6.2 (before i was in 6.0) i don't found my history data from Graph
    I didn't see error in my database log (PG)
    Do you have an idea ?
    (screenshot in attachment)
    Thanks in advance for your help
  • vladimir_lv
    • May 2022
    • 240
    What is History storage period for this item and are you using Override item history period option on Housekeeper?
    • Coll77
      • Dec 2020
      Thanks for your answer
      You will find the attachment 2 files (Storage period and housekeeping for this item)
      Thanks yet.
      • vladimir_lv
        • May 2022
        • 240
        Your settings allow you to keep trends for 365 days, so you have to see the data.
        When you had upgraded Zabbix? I see that the latest data for the item was collected almost 30 days ago.
        Is the item working now? Have you seen some errors in the zabbix_server.log or zabbix_proxy.log?
          • 4996
          Based on pics, its not history, what you are missing, but trends. Your settings force history to 8 days, so trying to look data for 30 days will display trends not history... If you look for "last week", it probably shows all?
          • Coll77
            • Dec 2020
            Hello vladimir_lv and cyber,
            Thanks to you it was this my problèm, i have put reset default housekeeping (not Override) and now i see my data on graph
            Thanks yet.
