Value of type "string" is not suitable for value type "Numeric (unsigned)"
  • christianmolecki
    • Nov 2017
    • 24
    Hello guys,
    some time ago I created own items to monitor the read/write speed for linux-partitions.
    Now the zabbix_server.log shows some type-problems.
    4336:20220728:210036.616 item "A-GWZDB01:vfs.dev.read[sdb1,sps,avg1]" became not supported: Value of type "string" is not suitable for value type "Numeric (unsigned)". Value "24099.466667"
    4335:20220728:210038.616 item "A-GWZDB01:vfs.dev.write[sdb1,sps,avg1]" became not supported: Value of type "string" is not suitable for value type "Numeric (unsigned)". Value "2.400000"
    Does the type of the return value has changed with Zabbix v6?
    - item settings
    BR
    Chris.
  • Answer selected by christianmolecki at 02-08-2022, 08:23.
    Hamardaban
    • May 2019
    • 2714
    Value "24099.466667" this is clearly not an integer (Numeric (unsigned))! :-)
    change the item Type of information -> Numeric (float)
    • Hamardaban
      • May 2019
      • 2714
      • vladimir_lv
        • May 2022
        • 240
        Hi!
        The same for vfs.dev.write, the type should be Numeric(Float)
        • christianmolecki
          • Nov 2017
          • 24
          Thank you guys. Some Items has been nummeric (integer) and not float.
          I was confused, becaused the message ment "Value of type "string" is not suitable"...
          [HASHTAG="t438"]solved[/HASHTAG]
