Problem with conf SSL/TLS encryption between Zabbix Server and MySQL database
  • zabix_dummy
    • Aug 2022
    Hi all,
    I am newbie in Zabbix and I try to deploy it using Docker, docker-compose file to be exact.
    Little by little I want to tweak every needed parameters and element. So I decided to use as a baseline official docker-compose files: zabbix/zabbix-docker: Official Zabbix Dockerfiles (github.com)
    I have VM wiht CentOS 8 and service stack as it follows:
    1. Ubuntu 6.2 image for Zabbix Server
    2. Ubuntu 6.2 image for mysql database
    3. Ubuntu 6.2 image for zabbix agent
    These are key components.
    I decided to start with self signed certificates using OpenSSL and bash script to generete them.
    #!/usr/bin/env bash
    mkdir -p ~/newcerts
    mkdir -p ~/zbx_env/var/lib/zabbix/ssl/certs
    mkdir -p ~/zbx_env/var/lib/zabbix/ssl/ssl_ca
    mkdir -p ~/zbx_env/var/lib/zabbix/ssl/keys
    mkdir -p ~/zbx_env/var/lib/zabbix/enc
    chmod 0750 ~/newcerts
    cd ~/newcerts
    # CA key
    openssl genrsa 2048 > ca-key.pem
    openssl req -new -x509 -nodes -days 365000 -key ca-key.pem -out ca-cert.pem -subj "/C=XX/ST=XX/L=XX/O=XX/OU=IT/CN=root-ca/[email protected]"
    # server key
    openssl req -newkey rsa:2048 -days 365000 -nodes -keyout server-key.pem -out server-req.pem -subj "/C=XX/ST=DOL/L=XX/O=XX/OU=IT/CN=mysql-server/[email protected]"
    openssl x509 -req -days 365000 -set_serial 01 \
    -in server-req.pem \
    -out server-cert.pem \
    -CA ca-cert.pem \
    -CAkey ca-key.pem
    # client key
    openssl req -newkey rsa:2048 -days 365000 -nodes -keyout client-key.pem -out client-req.pem -subj "/C=XX/ST=XX/L=XX/O=XX/OU=IT/CN=zabbix/[email protected]"
    -in client-req.pem \
    -out client-cert.pem \
    -CA ca-cert.pem \
    -CAkey ca-key.pem
    # check key ok
    openssl verify -CAfile ca-cert.pem server-cert.pem client-cert.pem
    # ls key
    ls ~/newcerts
    cd ~/
    mkdir env_vars
    cd env_vars
    yes | cp -rf ~/newcerts/ca-cert.pem ~/env_vars/.ZBX_DB_CA_FILE
    yes | cp -rf ~/newcerts/client-key.pem ~/env_vars/.ZBX_DB_KEY_FILE
    yes | cp -rf ~/newcerts/client-cert.pem ~/env_vars/.ZBX_DB_CERT_FILE
    yes | cp -rf ~/newcerts/server-cert.pem ~/env_vars/.DB_CERT_FILE
    yes | cp -rf ~/newcerts/server-key.pem ~/env_vars/.DB_KEY_FILE
    yes | cp -rf ~/newcerts/ca-cert.pem ~/env_vars/root-ca.pem
    yes | cp -rf ~/newcerts/client-key.pem ~/env_vars/client-key.pem
    yes | cp -rf ~/newcerts/client-cert.pem ~/env_vars/client-cert.pem
    yes | cp -rf ~/newcerts/server-cert.pem ~/env_vars/server-cert.pem
    yes | cp -rf ~/newcerts/server-key.pem ~/env_vars/server-key.pem
    yes | cp -rf ~/newcerts/ca-cert.pem ~/zbx_env/var/lib/zabbix/ssl/ssl_ca/root-ca.pem
    yes | cp -rf ~/newcerts/client-key.pem ~/zbx_env/var/lib/zabbix/ssl/keys/client-key.pem
    yes | cp -rf ~/newcerts/client-cert.pem ~/zbx_env/var/lib/zabbix/ssl/certs/client-cert.pem
    yes | cp -rf ~/newcerts/server-key.pem ~/zbx_env/var/lib/zabbix/ssl/keys/server-key.pem
    yes | cp -rf ~/newcerts/server-cert.pem ~/zbx_env/var/lib/zabbix/ssl/certs/server-cert.pem
    yes | cp -rf ~/newcerts/ca-cert.pem ~/zbx_env/var/lib/zabbix/enc/root-ca.pem
    yes | cp -rf ~/newcerts/client-key.pem ~/zbx_env/var/lib/zabbix/enc/client-key.pem
    yes | cp -rf ~/newcerts/client-cert.pem ~/zbx_env/var/lib/zabbix/enc/client-cert.pem zz0.q3vy5ub4z6nzz
    And this is my docker-compose.yml file:
    version: '3.5'
    services:
      zabbix-server:
        image: zabbix/zabbix-server-mysql:ubuntu-6.2-latest
        ports:
          - "10051:10051"
        hostname:  zabbix-server
        environment:
          - DB_SERVER_PORT=3306
        volumes:
          - ./env_vars/root-ca.pem:/usr/share/ca-certificates/root-ca.crt:ro
          - /etc/localtime:/etc/localtime:ro
          - ./zbx_env/usr/lib/zabbix/alertscripts:/usr/lib/zabbix/alertscripts:ro
          - ./zbx_env/usr/lib/zabbix/externalscripts:/usr/lib/zabbix/externalscripts:ro
          - ./zbx_env/var/lib/zabbix/export:/var/lib/zabbix/export:rw
          - ./zbx_env/var/lib/zabbix/modules:/var/lib/zabbix/modules:ro
          - ./zbx_env/var/lib/zabbix/enc:/var/lib/zabbix/enc:ro
          - ./zbx_env/var/lib/zabbix/ssh_keys:/var/lib/zabbix/ssh_keys:ro
          - ./zbx_env/var/lib/zabbix/mibs:/var/lib/zabbix/mibs:ro
          - snmptraps:/var/lib/zabbix/snmptraps:rw
        ulimits:
          nproc: 65535
          nofile:
            soft: 20000
            hard: 40000
        deploy:
          resources:
            limits:
              cpus: '0.70'
              memory: 1G
            reservations:
              cpus: '0.5'
              memory: 512M
        env_file:
          - ./env_vars/.env_db_mysql
          - ./env_vars/.env_srv
        secrets:
          - MYSQL_USER
          - MYSQL_PASSWORD
          - MYSQL_ROOT_USER
          - MYSQL_ROOT_PASSWORD
          - client-key.pem
          - client-cert.pem
          - root-ca.pem
        depends_on:
          - mysql-server
        networks:
          zbx_net_backend:
            aliases:
              - zabbix-server
              - zabbix-server-mysql
              - zabbix-server-ubuntu-mysql
              - zabbix-server-mysql-ubuntu
          zbx_net_frontend:
            #  devices:
            #   - "/dev/ttyUSB0:/dev/ttyUSB0"
        stop_grace_period: 30s
        sysctls:
          - net.ipv4.ip_local_port_range=1024 65000
          - net.ipv4.conf.all.accept_redirects=0
          - net.ipv4.conf.all.secure_redirects=0
          - net.ipv4.conf.all.send_redirects=0
        labels:
          com.zabbix.description: "Zabbix server with MySQL database support"
          com.zabbix.company: "Zabbix LLC"
          com.zabbix.component: "zabbix-server"
          com.zabbix.dbtype: "mysql"
          com.zabbix.os: "ubuntu"
      zabbix-web-apache-mysql:
        image: zabbix/zabbix-web-apache-mysql:ubuntu-6.2-latest
        ports:
          - "8081:8080"
          - "8443:8443"
        hostname: zabbix-web-apache-mysql
        volumes:
          - ./env_vars/cert.pem:/usr/share/ca-certificates/mozilla/zabbix-cert.crt:ro
          - ./zbx_env/etc/ssl/apache2:/etc/ssl/apache2:ro
          - ./zbx_env/usr/share/zabbix/modules/:/usr/share/zabbix/modules/:ro
        deploy:
          resources:
            limits:
              cpus: '0.70'
              memory: 512M
            reservations:
              cpus: '0.5'
              memory: 256M
        env_file:
          - ./env_vars/.env_web
        secrets:
          - MYSQL_USER
          - MYSQL_PASSWORD
          - client-key.pem
          - client-cert.pem
          - root-ca.pem
        depends_on:
          - mysql-server
          - zabbix-server
        healthcheck:
          test: [ "CMD", "curl", "-f", "http://localhost:8080/" ]
          interval: 10s
          timeout: 5s
          retries: 3
          start_period: 30s
        networks:
          zbx_net_backend:
            aliases:
              - zabbix-web-apache-mysql
              - zabbix-web-apache-ubuntu-mysql
              - zabbix-web-apache-mysql-ubuntu
          zbx_net_frontend:
        stop_grace_period: 10s
        sysctls:
          - net.core.somaxconn=65535
        labels:
          com.zabbix.description: "Zabbix frontend on Apache web-server with MySQL database support"
          com.zabbix.component: "zabbix-frontend"
          com.zabbix.webserver: "apache2"
      zabbix-agent:
        image: zabbix/zabbix-agent:ubuntu-6.2-latest
        ports:
          - "10050:10050"
        hostname: zabbix-agent
        volumes:
          - ./zbx_env/etc/zabbix/zabbix_agentd.d:/etc/zabbix/zabbix_agentd.d:ro
        deploy:
          resources:
            limits:
              cpus: '0.2'
              memory: 128M
            reservations:
              cpus: '0.1'
              memory: 64M
          mode: global
        env_file:
          - ./env_vars/.env_agent
        privileged: true
        pid: "host"
        networks:
          zbx_net_backend:
            aliases:
              - zabbix-agent
              - zabbix-agent-passive
              - zabbix-agent-ubuntu
        stop_grace_period: 5s
        labels:
          com.zabbix.description: "Zabbix agent"
          com.zabbix.component: "zabbix-agentd"
      zabbix-snmptraps:
        image: zabbix/zabbix-snmptraps:ubuntu-6.2-latest
        ports:
          - "162:1162/udp"
        hostname: zabbix-snmptraps
        volumes:
        deploy:
          resources:
            limits:
              cpus: '0.5'
              memory: 256M
            reservations:
              cpus: '0.25'
              memory: 128M
        networks:
          zbx_net_frontend:
            aliases:
              - zabbix-snmptraps
          zbx_net_backend:
        labels:
          com.zabbix.description: "Zabbix snmptraps"
          com.zabbix.component: "snmptraps"
      mysql-server:
        image: mysql:8.0-oracle
        hostname : mysql-server
        command:
          - mysqld
          - --character-set-server=utf8mb4
          - --collation-server=utf8mb4_bin
          #- --authentication-policy='caching_sha2_passowrd,sha256_password'
          - --default-authentication-plugin=mysql_native_password
          - --require-secure-transport
          - --ssl-ca=/run/secrets/root-ca.pem
          - --ssl-cert=/run/secrets/server-cert.pem
          - --ssl-key=/run/secrets/server-key.pem
        volumes:
          - ./env_vars/cert.pem:/etc/pki/tls/cert.pem:rw
          - ./zbx_env/var/lib/mysql:/var/lib/mysql:rw
        env_file:
        secrets:
          - MYSQL_USER
          - MYSQL_PASSWORD
          - server-key.pem
          - server-cert.pem
          - root-ca.pem
        stop_grace_period: 1m
        networks:
          zbx_net_backend:
            aliases:
              - mysql-server
              - zabbix-database
              - mysql-database
      db_data_mysql:
        image: busybox
        volumes:
    networks:
      zbx_net_frontend:
        driver: bridge
        driver_opts:
          com.docker.network.enable_ipv6: "false"
        ipam:
          driver: default
          config:
            - subnet: 172.16.238.0/24
      zbx_net_backend:
        driver: bridge
        driver_opts:
        internal: true
        ipam:
          driver: default
          config:
            - subnet: 172.16.239.0/24
    volumes:
      snmptraps:
    secrets:
      MYSQL_USER:
        file: ./env_vars/.MYSQL_USER
      MYSQL_PASSWORD:
        file: ./env_vars/.MYSQL_PASSWORD
      MYSQL_ROOT_USER:
        file: ./env_vars/.MYSQL_ROOT_USER
      MYSQL_ROOT_PASSWORD:
        file: ./env_vars/.MYSQL_ROOT_PASSWORD
      client-key.pem:
        file: ./env_vars/.ZBX_DB_KEY_FILE
      client-cert.pem:
        file: ./env_vars/.ZBX_DB_CERT_FILE
      root-ca.pem:
        file: ./env_vars/.ZBX_DB_CA_FILE
      server-cert.pem:
        file: ./env_vars/.DB_CERT_FILE
      server-key.pem:
        file: ./env_vars/.DB_KEY_FILE zz0.s5h4ulicw2izz
    This is my logs for DB:
    Error response from daemon: Multiple IDs found with provided prefix: 5
    [zabbixuser@ZabbixSrv ~]$ docker logs 5f38
    2022-07-29 13:53:13+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.30-1.el8 started.
    2022-07-29 13:53:14+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
    2022-07-29 13:53:14+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.30-1.el8 started.
    '/var/lib/mysql/mysql.sock' -> '/var/run/mysqld/mysqld.sock'
    2022-07-29T13:53:14.355785Z 0 [B][Warning][/B] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
    2022-07-29T13:53:14.357815Z 0 [B][Warning][/B] [MY-010918] [Server] 'default_authentication_plugin' is deprecated and will be removed in a future release. Please use authentication_policy instead.
    2022-07-29T13:53:14.357839Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.30) starting as process 1
    2022-07-29T13:53:14.364997Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    2022-07-29T13:53:14.787783Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
    2022-07-29T13:53:15.204651Z 0 [Warning] [MY-010068] [Server] CA certificate /run/secrets/root-ca.pem is self signed.
    2022-07-29T13:53:15.204693Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
    2022-07-29T13:53:15.215510Z 0 [B][Warning] [/B][MY-011810] [Server] Insecure configuration for --pid-file: Location '/var/run/mysqld' in the path is accessible to all OS users. Consider choosing a different directory.
    2022-07-29T13:53:15.233901Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '::' port: 33060, socket: /var/run/mysqld/mysqlx.sock
    2022-07-29T13:53:15.233916Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '8.0.30' socket: '/var/run/mysqld/mysqld.sock' port: 3306 MySQL Community Server - GPL.
    And this are logs from Zabbix Server:
    224:20220729:133008.089 [Z3005] query failed: [2013] Lost connection to MySQL server during query [insert into history (itemid,clock,ns,value) values (42247,1659101407,721217705,0.125198);
    224:20220729:133008.090 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    224:20220729:133008.090 database is down: reconnecting in 10 seconds
    228:20220729:133008.348 [Z3005] query failed: [1053] Server shutdown in progress [select escalationid,actionid,triggerid,eventid,r_eventid,nextcheck,esc_step,status,itemid,acknowledgeid,servicealarmid,serviceid from escalations where triggerid is not null and nextcheck<=1659101411 order by actionid,triggerid,itemid,escalationid]
    228:20220729:133008.349 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    228:20220729:133008.349 database is down: reconnecting in 10 seconds
    250:20220729:133008.396 [Z3005] query failed: [2013] Lost connection to MySQL server during query [select a.alertid,a.mediatypeid,a.sendto,a.subject,a.message,a.status,a.retries,e.source,e.object,e.objectid,a.parameters,a.eventid,a.p_eventid from alerts a left join events e on a.eventid=e.eventid where alerttype=0 and a.status=3 order by a.alertid]
    250:20220729:133008.397 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    250:20220729:133008.397 database is down: reconnecting in 10 seconds
    227:20220729:133009.098 [Z3005] query failed: [2013] Lost connection to MySQL server during query [insert into history (itemid,clock,ns,value) values (42248,1659101408,722826669,0);
    227:20220729:133009.099 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    227:20220729:133009.099 database is down: reconnecting in 10 seconds
    206:20220729:133010.041 [Z3005] query failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111) [begin;]
    226:20220729:133010.099 [Z3005] query failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111) [begin;]
    226:20220729:133010.099 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    226:20220729:133010.099 database is down: reconnecting in 10 seconds
    237:20220729:133010.129 [Z3005] query failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111) [select taskid,type,clock,ttl from task where status in (1,2) order by taskid]
    237:20220729:133010.129 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    237:20220729:133010.130 database is down: reconnecting in 10 seconds
    206:20220729:133011.042 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    206:20220729:133012.064 [Z3001] connection to database 'zabbix' failed: [2005] Unknown MySQL server host 'mysql-server' (-2)
    206:20220729:133013.063 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    225:20220729:133013.147 [Z3005] query failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111) [begin;]
    225:20220729:133013.148 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111)
    225:20220729:133013.148 database is down: reconnecting in 10 seconds
    222:20220729:133013.403 [Z3005] query failed: [2003] Can't connect to MySQL server on 'mysql-server:3306' (111) [select h.hostid,h.host,h.name,t.httptestid,t.name,t.agent,t.authentication,t.http_user,t.http_password,t.http_proxy,t.retries,t.ssl_cert_file,t.ssl_key_file,t.ssl_key_password,t.verify_peer,t.verify_host,t.delay from httptest t,hosts h where t.hostid=h.hostid and t.nextcheck<=1659101412 and mod(t.httptestid,1)=0 and t.status=0 and h.proxy_hostid is null and h.status=0 and (h.maintenance_status=0 or h.maintenance_type=0)]
