Having trouble installing Zabbix 6.2
  • rubix8
    • Aug 2022
    So, i am following the steps shown in the Zabbix site. During the installation, it errors out and get the following issue, which i cannot resolve:
    root@zabbix tmp]# sudo yum localinstall zabbix-release-6.2-2.el9.noarch.rpm
    Loaded plugins: fastestmirror
    Examining zabbix-release-6.2-2.el9.noarch.rpm: zabbix-release-6.2-2.el9.noarch
    Marking zabbix-release-6.2-2.el9.noarch.rpm as an update to zabbix-release-4.0-1.el7.noarch
    Resolving Dependencies
    --> Running transaction check
    ---> Package zabbix-release.noarch 0:4.0-1.el7 will be updated
    ---> Package zabbix-release.noarch 0:6.2-2.el9 will be an update
    --> Finished Dependency Resolution
    Dependencies Resolved
    Package Arch Version Repository Size
    Updating:
    zabbix-release noarch 6.2-2.el9 /zabbix-release-6.2-2.el9.noarch 22 k
    Transaction Summary
    Upgrade 1 Package
    Total size: 22 k
    Is this ok [y/d/N]: y
    Downloading packages:
    ERROR You need to update rpm to handle:
    rpmlib(PayloadIsZstd) <= 5.4.18-1 is needed by zabbix-release-6.2-2.el9.noarch
    RPM needs to be updated
    You could try running: rpm -Va --nofiles --nodigest
    Your transaction was saved, rerun it with:
    yum load-transaction /tmp/yum_save_tx.2022-08-03.15-33.V3ri0N.yumtx
    [root@zabbix tmp]#
    I am running CentOS7.
    4GB of memory
    80GB of storage.
    Please let me know if there is a trick to resolving this issue.
    Thank you in Adv.
    • 4996
    Lets start with the fact, that you cannot install Zabbix 6.2 on CentOS7 (you are trying to install packages for el9 on 7..) ... Its just too old and has many unresolved dependencies. One of them, as we see here, is the version of "rpm". https://www.zabbix.com/documentation...n/requirements
    Already 6.0 was not possible to install on CentOS(or RH) 7 ...
