fping: Cannot allocate memory
  • heath
    • Aug 2022
    Hi, I'm a beginner to Zabbix
    I deployed Zabbix with docker-compose and see these msgs from server log
    What cause and how to solve this?
  • vladimir_lv
    • May 2022
    • 240
    Looks like you have to increase the server memory.
    • tim.mooney
      • Dec 2012
      • 1436
      I'm not using the docker images for my site's Zabbix install so it's not clear to me: is fping inside one of the docker containers, or is it installed on your OS?
      I ask because some distros don't install fping setuid root or with the necessary capabilities(5) to allow it to work correctly unless it's run by the root user. Since the Zabbix install runs as a non-privileged user, fping may not have the necessary access it needs.
      If fping is part of your distro and not part of the Docker container, you probably need to look into what the best way is to give it the capabilities it needs for your distro.
      • heath
        • Aug 2022
        Assigned 8GB memory to server container. And I run
        docker stat
        , memory is enough
        • heath
          • Aug 2022
          Thx for your reply, fping is inside server container
          • juniorogs
            • Sep 2022
            health, did you manage to solve this problem? recently i've got upgraded from 5.0 to 6.0 using zabbix-docker image and im having the same scenario as you described.
            • zkry.akgul
              • Sep 2022
              Hi, did you guys find any solution about this issue? Im using zabbix 6.2 inside the docker container and im facing the exact same issue in my setup.
              • juniorogs
                • Sep 2022
                While I was doing the tests, I ran zabbix docker in another instance (with a newer S.O Version) and it didn't show these errors.. I believe it may be something related to some configuration or limitation of the operating system that runs docker, or either the docker version installed, but I still don't have any conclusions about it.
                ​A workaround suggestion is to try to run it in another instance with another version of the linux distribution, a newer or a different one.
                • FabrizioA
                  • Sep 2015
                  • 33
                  You can resolve this problem by run container in privileged mode.
                  You can edit your compose's yaml file as something like this:
                  web:
                  image: an_image-image:1.0
                  container_name: my-container
                  privileged: true
                  entrypoint: ["/usr/sbin/init"]
                  ports:
                  - "8280:8280"​
