zabbix server not activating
  • albert_jose
    • Aug 2022
    [root@server2 ~]# systemctl status zabbix-server
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
    Active: activating (auto-restart) (Result: exit-code) since Thu 2022-08-11 15:18:59 IST; 8s ago
    Process: 9454 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
    Main PID: 9458 (code=exited, status=1/FAILURE)
    Aug 11 15:18:59 server2.example.com systemd[1]: zabbix-server.service: Main process exited, code=exited, status=1/FAILURE
    Aug 11 15:18:59 server2.example.com systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    [root@server2 ~]# ^C
    attaching logs also
    9588:20220811:152032.161 Starting Zabbix Server. Zabbix 4.2.8 (revision cb5d5b10f4).
    9588:20220811:152032.161 ****** Enabled features ******
    9588:20220811:152032.161 SNMP monitoring: YES
    9588:20220811:152032.161 IPMI monitoring: YES
    9588:20220811:152032.161 Web monitoring: YES
    9588:20220811:152032.161 VMware monitoring: YES
    9588:20220811:152032.161 SMTP authentication: YES
    9588:20220811:152032.161 Jabber notifications: NO
    9588:20220811:152032.161 Ez Texting notifications: YES
    9588:20220811:152032.161 ODBC: YES
    9588:20220811:152032.161 SSH2 support: YES
    9588:20220811:152032.161 IPv6 support: YES
    9588:20220811:152032.161 TLS support: YES
    9588:20220811:152032.161 ******************************
    9588:20220811:152032.161 using configuration file: /etc/zabbix/zabbix_server.conf
    9588:20220811:152032.166 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    [root@server2 ~]#
    • 5004
    Seems like your DB has not been set up properly... no tables created or something...
    • Hamardaban
      • May 2019
      • 2714
      Have you done all the steps according to this instruction?
