Macros in calls do not work anymore
  • gullevek
    • Nov 2008
    • 22
    I have some calls in the form of net.tcp.port[{HOST.IP1},<PORT>]
    Since I upgraded to 3.0 I cannot get them to work anymore. In the call itself the Macro is not replaced anymore. It is still replaced in the title for the Trigger itself.
    When I turn debugging on I get the data below:
    <PORT>: target port
    <HOST NAME>: visible host name in the log
    <IP>: visible IP in the system
    12873:20160303:163630.582 In get_value() key:'net.tcp.port[{HOST.IP1},<PORT>]'
    12873:20160303:163630.582 In get_value_agent() host:'<HOST NAME>' addr:'<IP>' key:'net.tcp.port[{HOST.IP1},<PORT>]' conn:'unencrypted'
    12873:20160303:163630.582 Sending [net.tcp.port[{HOST.IP1},<PORT>]
    If I create a new entry and use a defined Macro from the host and eg call it {$HOSTIP} and set it to the IP of the target host, it works.
    A second example from the log:
    12877:20160303:163632.188 In substitute_key_macros() data:'net.tcp.port[{HOST.IP1},<PORT>]'
    12877:20160303:163632.188 In substitute_simple_macros() data:'{HOST.IP1}'
    12877:20160303:163632.188 End substitute_simple_macros() data:'{HOST.IP1}'
    12877:20160303:163632.188 End of substitute_key_macros():SUCCEED data:'net.tcp.port[{HOST.IP1},<PORT>]'
    12877:20160303:163632.188 In substitute_simple_macros() data:'10050'
    12877:20160303:163632.188 In get_value() key:'net.tcp.port[{HOST.IP1},<PORT>]'
    12877:20160303:163632.188 In get_value_agent() host:'<HOST NAME>' addr:'<IP>' key:'net.tcp.port[{HOST.IP1},<PORT>]' conn:'unencrypted'
    12877:20160303:163632.188 Sending [net.tcp.port[{HOST.IP1},<PORT>]
  • glebs.ivanovskis
    • Jul 2015
    • 237
    Please read Upgrade notes carefully.
