Template "Kubernetes nodes by HTTP" fails to discover
  • Marco Gastreghini
    • Mar 2021
    I installed the "Kubernetes nodes by HTTP" Template on Zabbix 6.0.3, but I can't get it to work because the Kubernetes discovery doesn't start.
    I created a node for the k8s cluster and I also filled in correctly the macros {$ KUBE.API.ENDPOINT.URL} and {$ KUBE.API.TOKEN}.
    In the Zabbix server log there are these messages:
    332304: 20220825: 102300.961 [Kubernetes] ERROR: Error: cannot get URL: Couldn't connect to server.
    332280: 20220825: 102300.964 [Kubernetes discovery] ERROR: Incorrect JSON. Check debug log for more information.
    332280: 20220825: 102300.965 [Kubernetes discovery] ERROR: Incorrect JSON. Check debug log for more information.
    I don't understand why the Zabbix server can't contact the kubernetes cluster.
    Thanks in advance.
    MG
    • 4996
    Connection issues? Can you connect from command line with curl?
    • Marco Gastreghini
      • Mar 2021
      OK. Wrong Kubernetes API Endpoint IP... Sorry.
      But now error messages change:
      332304:20220825:150000.560 [ Kubernetes ] ERROR: Request failed with status code 403: {"kind":"Status","apiVersion":"v1","metadata":{ }," status":"Failure","message":"forbidden: User "system:serviceaccount:monitoring:zabbix-service-account" cannot get path "/v1/nodes"","reason":"Forbidden","details":{},"code": 403}
      332280:20220825:150000.562 [ Kubernetes discovery ] ERROR: Incorrect JSON. Check debug log for more information.
      332280:20220825:150000.563 [ Kubernetes discovery ] ERROR: Incorrect JSON. Check debug log for more information.
      MG
        • 4996
        That looks more like a permission issue on Kubernetes side... http 403 is "Forbidden".
        Do you really have username like "system:serviceaccount:monitoring:zabbix-service-account" ? Or maybe just part of it?
        • Marco Gastreghini
          • Mar 2021
          RESOLVED: wrong string in Macro {$KUBE.API.ENDPOINT.URL} without /api on tail.
          Many thanks
          MG
