Item.key[{$MACRO}] with trapper
  • watm24
    • Apr 2022
    I have trouble with delivering data from zabbix_sender to item with user macro defined.
    OS version:
    root@lora:/var/log/zabbix# lsb_release -a
    No LSB modules are available.
    Distributor ID: Ubuntu
    Description: Ubuntu 18.04.6 LTS
    Release: 18.04
    Codename: bionic
    Server version:
    root@lora:/var/log/zabbix# zabbix_server -V
    zabbix_server (Zabbix) 5.4.12
    Revision 9bd5a418b8 4 April 2022, compilation time: Apr 4 2022 08:20:16
    Host 'dev-test-7' has user macro defined
    Also this host have items configured. One with macro, one static.
    Delivering data from zabbix_sender works only for static item.
    root@lora:/var/log/zabbix# zabbix_sender -z 127.0.0.1 -s dev-test-7 -k rs485_[2] -o 2
    Response from "127.0.0.1:10051": "processed: 1; failed: 0; total: 1; seconds spent: 0.000066"
    sent: 1; skipped: 0; total: 1
    root@lora:/var/log/zabbix# zabbix_sender -z 127.0.0.1 -s dev-test-7 -k rs485[2] -o 2
    Response from "127.0.0.1:10051": "processed: 0; failed: 1; total: 1; seconds spent: 0.000036"
    Please help me solve this problem.
  • watm24
    • Apr 2022
    Found this note
    https://www.zabbix.com/documentation...mtypes/trapper
    Attention: Zabbix trapper process does not expand macros used in the item key in attempt to check corresponding item key existence for targeted host.
    Sadly it looks like it's unsupported for now.
    Even in 6.2.
