item key does not support with [ ] brackets
  • gopkris2000
    • Feb 2020
    • 15
    I have tried to add a new item key to capture the read-only directory using the below command.
    Key​
    system.run[ [ -w /mount-dir ] && echo "rw" || echo "ro" ]
    but it is failing with the below errors to test.
    • Incorrect value for field "key_": incorrect syntax near "&& echo "rw" || echo "ro" ]".
    ​what is the best way to add [ ] in the item key?
    • 5004
    system.run[test -w /mount-dir && echo "rw" || echo "ro" ]
    Or follow docs https://www.zabbix.com/documentation...nquoted-string
    use ""-s to quote parameters for a key.
    If the key parameter is an unquoted string, any Unicode character is allowed except comma and right square bracket (]). Unquoted parameter cannot start with left square bracket ([).
    system.run[" [ -w /mount-dir ] && echo \"rw\" || echo \"ro\" "]
    • gopkris2000
      • Feb 2020
      • 15
      It is working fine. Thanks, cyber, however, it is returning "ro" only from the items key test but the directory which I tested is writable.
      Any Idea how can we get "read-only" file system errors to the mounted partitions?
      Appreciated.
        • 5004
        Writable to whom? Maybe they are not writeable for user zabbix?
        test -w is checking if write permission is given... It depends on, who is asking...
        Just testing the same here with very obvious /tmp and /root directories... /tmp as usual is world writeable and gives me rw as answer... /root is owned by root an no other permissions given, gives me ro. /boot gives also ro, as I cannot write there.
        Switching to root, same commands give me rw as answer as root can write everywhere...
        • gopkris2000
          • Feb 2020
          • 15
          Thanks cyber It worked what I expected after enabled AllowRoot in zabbix configuration.
