Wildcards in agent config
  • baldymaldy
    • Aug 2022
    This is my first post. Hello everyone
    I am having problems using wildcards under the following parameter in Zabbix Agent2 6.0.6 on RHEL7:
    ### Option: Server
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    # Incoming connections will be accepted only from the hosts listed here.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    # and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    I have to add about 30 servers and the amount is a subject to change.
    Example:
    myexampleserver001.com
    myexampleserver002.com
    myexampleserver*.com
    I tried myexampleserver*.com but doesn't seem to work.
    Any tips? Specifying IP and/or range/subnet is out of question unfortunately. DNS names only.
    Thanks in advance!
    • 5004
    What's the reason for so many servers?
    But wildcards do not work there... Either you need to specify all of them or use network range.
    • baldymaldy
      • Aug 2022
      Hi cyber,
      The Kubernetes cluster I'm using has Zabbix backend deployed. I defined the DNS name of ingress in Agent config. This is not enough unfortunately and I'm getting "connection reset by peer" errors.
      The reason is, the actual servers communicating between Zabbix backend and Agents (these are external servers outside of K8s cluster) are K8s nodes.
      The backend can be evicted from one node to another or another replica/pod can be created under different node. Their IP address are a subject to change (like in every other enterprise environment).Waking up one day with a need to change config on 150 hosts might not be the best experience..
      Hence why I wanted to use a wildcard and DNS names.
      But I suppose you already answered my questions and I have to use network range... thank you!
        • 5004
        It all again confirms my belief that "anything container" is evil..
