Slack Webhook Issue
  • billnnm
    • May 2022
    Slack Webhook Issue
    After following the instructions outlined on https://www.zabbix.com/integrations/slack then applying the schema fix on https://www.zabbix.com/forum/zabbix-...hook-in-zabbix, running a test for the webhook results in the error "Slack notification failed : ReferenceError: identifier 'CurlHttpRequest' undefined".
    Below are the server's specs in case they're needed to diagnose the issue:
    • Zabbix: 6.2.2
    • OS: AlmaLinux 8.6
    • PHP: 7.4.30
    • MySQL: 8.0.26
  • Atsushi
    • Aug 2013
    • 2028
    Maybe the script you're using is outdated? The post referenced is from about 2 years ago. I think I used CurlHttpRequest until Zabbix 5.4.
    If you are using Zabbix 6.2, please re-import the Slack settings for Zabbix 6.2 and set them.
    https://git.zabbix.com/projects/ZBX/...lease%2F6.2​
    • billnnm
      • May 2022
      Atsushi Changing the "CurlHttpRequest" strings did help. Running a test of the Slack media type now works, but the alert notifications aren't being sent to Slack automatically. I'm pretty confident I set up all users with the appropriate settings and permissions for it to work but maybe I missed something. If you have any thoughts there, I'm open to suggestions.
      • vcnt
        • Jul 2021
        • 11
        hi, the same problem is happening to me. i´m using mediatypes slack from 6.4, this link. -> https://git.zabbix.com/projects/ZBX/...2FDEV-2204-6.2
        my zabbix server was updating to 6.4 recently, after this, we cant send notifications on slack...
        when i will send a test, this error appears.
        • Slack notification failed : TypeError: undefined not callable (property 'AddHeader' of [object Object])
        i saw something on fweb, about change some characteres on yaml file, but it doesnt work for me. any solutions for 6.4 zabbix?​
        • goat90
          • Sep 2024
          @vcnt And for rest of You which have the same problem. Just import mediatype Slack in version 6.2 and it works. Make sure to mark checkbox Update Existing during Import.
