Zabbix DB version mismatch current requirements
  • Nir Pery
    • Sep 2022
    • 12
    I’m new in Zabbix.
    I have a Kubernetes cluster and I tried to implant Zabbix on it.
    I created 3 pods-
    1. PostgreSQL - version 14.5.1
    2. Zabbix-server-pgsql - version 6.2.7
    3. Zabbix-web-nginx-pgsql - version 6.0.7
    After all, I got into the frontend but got an error:
    “The Zabbix db version doesn’t match…
    Your db version is: 60200000. Required version is: 6000000.”
    I think it might be because the mismatch between Zabbix server and frontend.
    Am I right?
    should I update the frontend version or to downgrade the server version to 6.0.7.
    Thank you very much!
    • 4996
    Thou shall not use mismatched versions .. Whatever way you go, make versions equal.
    • Nir Pery
      • Sep 2022
      • 12
      Actually, someone else downloaded those images.
      I saw it yesterday.
      I will match the versions, hope it will work.
      Thank you.
      • Nir Pery
        • Sep 2022
        • 12
        I downloaded the same version for both Zabbix-Server and Frontend(6.0.7) and there is still a problem.
        Do you have any suggestions?
        Thanks.
        • Atsushi
          • Aug 2013
          • 2028
          If the database version has been upgraded for Zabbix 6.2, it cannot be used with Zabbix 6.0.
          If you have a backup of the database that was used with Zabbix 6.0, try using the Zabbix 6.0 package after reverting to the database for 6.0. If you don't have a backup of your database from Zabbix 6.0, consider using Zabbix 6.2.​
            • 4996
            As already said... if your server is already 6.2 and seems to be fine, then just get correct GUI version. Downgrading is more trouble than that....
            • Nir Pery
              • Sep 2022
              • 12
              Thanks. Resolved.
              I deleted the DB(it was empty anyway) and recreated it.
              Then i just installed the server and web again.
