A connection timeout occurred error
  • paw
    • Sep 2022
    Hi there!
    I spent a lot of time to configure zabbix agent active check. But all the time i catch that error
    "active check configuration update from [zabbix-server-ip:10051] started to fail (cannot connect to [[zabbix-server-ip]:10051]: A connection timeout occurred)".
    //-----Agent-config----//
    # This is a configuration file for Zabbix agent service (Windows)
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: LogType
    # Specifies where log messages are written to:
    # system - Windows event log
    # file - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: no
    # Default:
    # LogFile=
    LogFile=Path to conf file
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: AllowKey
    # Allow execution of item keys matching pattern.
    # Multiple keys matching rules may be defined in combination with DenyKey.
    # Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
    # Parameters are processed one by one according their appearance order.
    # If no AllowKey or DenyKey rules defined, all keys are allowed.
    # Mandatory: no
    ### Option: DenyKey
    # Deny execution of items keys matching pattern.
    # Multiple keys matching rules may be defined in combination with AllowKey.
    # Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
    # Mandatory: no
    # Default:
    AllowKey=system.run[*]
    ### Option: EnableRemoteCommands - Deprecated, use AllowKey=system.run[*] or DenyKey=system.run[*] instead
    # Internal alias for AllowKey/DenyKey parameters depending on value:
    # 0 - DenyKey=system.run[*]
    # 1 - AllowKey=system.run[*]
    # Mandatory: no
    ### Option: LogRemoteCommands
    # Enable logging of executed shell commands as warnings.
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    # LogRemoteCommands=0
    ##### Passive checks related
    ### Option: Server
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    # Incoming connections will be accepted only from the hosts listed here.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.domain
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    Server=zabbix-server-ip
    ### Option: ListenPort
    # Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    ### Option: ListenIP
    # List of comma delimited IP addresses that the agent should listen on.
    # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StartAgents
    # Number of pre-forked instances of zabbix_agentd that process passive checks.
    # If set to 0, disables passive checks and the agent will not listen on any TCP port.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAgents=3
    ##### Active checks related
    ### Option: ServerActive
    # List of comma delimited IP: port (or DNS name: port) pairs of Zabbix servers and Zabbix proxies for active checks.
    # If port is not specified, default port is used.
    # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    # If port is not specified, square brackets for IPv6 addresses are optional.
    # If this parameter is not specified, active checks are disabled.
    # Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    # Mandatory: no
    # Default:
    # ServerActive=
    ServerActive=zabbix-server-ip
    ### Option: Hostname
    # List of comma delimited unique, case sensitive hostnames.
    # Required for active checks and must match hostnames as configured on the server.
    # Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=hostname
    ### Option: HostnameItem
    # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    # Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    ### Option: HostMetadata
    # Optional parameter that defines host metadata.
    # Host metadata is used at host auto-registration process.
    # An agent will issue an error and not start if the value is over limit of 255 characters.
    # If not defined, value will be acquired from HostMetadataItem.
    # Mandatory: no
    # Range: 0-255 characters
    # Default:
    # HostMetadata=
    ### Option: HostMetadataItem
    # Optional parameter that defines an item used for getting host metadata.
    # During an auto-registration request an agent will log a warning message if
    # the value returned by specified item is over limit of 255 characters.
    # This option is only used when HostMetadata is not defined.
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    ### Option: HostInterface
    # Optional parameter that defines host interface.
    # Host interface is used at host auto-registration process.
    # If not defined, value will be acquired from HostInterfaceItem.
    # Mandatory: no
    # Default:
    # HostInterface=
    ### Option: HostInterfaceItem
    # Optional parameter that defines an item used for getting host interface.
    # This option is only used when HostInterface is not defined.
    # Mandatory: no
    # Default:
    # HostInterfaceItem=
    ### Option: RefreshActiveChecks
    # How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # RefreshActiveChecks=120
    ### Option: BufferSend
    # Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    # Maximum number of values in a memory buffer. The agent will send
    # all collected data to Zabbix server or Proxy if the buffer is full.
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    ### Option: MaxLinesPerSecond
    # Maximum number of new lines the agent will send per second to Zabbix Server
    # or Proxy processing 'log', 'logrt' and 'eventlog' active checks.
    # The provided value will be overridden by the parameter 'maxlines',
    # provided in 'log', 'logrt' or 'eventlog' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # MaxLinesPerSecond=20
    ############ ADVANCED PARAMETERS #################
    ### Option: Alias
    # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
    # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
    # Different Alias keys may reference the same item key.
    # For example, to retrieve paging file usage in percents from the server:
    # Alias=pg_usage: perf_counter[\Paging File(_Total)\% Usage]
    # Now shorthand key pg_usage may be used to retrieve data.
    # Aliases can be used in HostMetadataItem but not in HostnameItem or PerfCounter parameters.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    # Spend no more than Timeout seconds on processing.
    # Mandatory: no
    # Range: 1-30
    # Default:
    Timeout=30
    ### Option: PerfCounter
    # Syntax: <parameter_name>,"<perf_counter_path>",<period>
    # Defines new parameter <parameter_name> which is an average value for system performance counter <perf_counter_path> for the specified time period <period> (in seconds).
    # For example, if you wish to receive average number of processor interrupts per second for last minute, you can define new parameter "interrupts" as following:
    # PerfCounter = interrupts,"\Processor(0)\Interrupts/sec",60
    # Please note double quotes around performance counter path.
    # Samples for calculating average value will be taken every second.
    # You may run "typeperf -qx" to get list of all performance counters available in Windows.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Include
    # You may include individual files in the configuration file.
    # Mandatory: no
    # Default:
    # Include=
    # Include=c:\zabbix\zabbix_agentd.userparams.conf
    # Include=c:\zabbix\zabbix_agentd.conf.d\
    # Include=c:\zabbix\zabbix_agentd.conf.d\*.conf
    ### Option: UnsafeUserParameters
    # Allow all characters to be passed in arguments to user-defined parameters.
    # The following characters are not allowed:
    # Additionally, newline characters are not allowed.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # UnsafeUserParameters=0
    ### Option: UserParameter
    # User-defined parameter to monitor. There can be several user-defined parameters.
    # Format: UserParameter=<key>,<shell command>
    # Mandatory: no
    # Default:
    # UserParameter=
    ### Option: UserParameterDir
    # Directory to execute UserParameter commands from. Only one entry is allowed.
    # When executing UserParameter commands the agent will change the working directory to the one
    # specified in the UserParameterDir option.
    # This way UserParameter commands can be specified using the relative ./ prefix.
    # Mandatory: no
    # Default:
    # UserParameterDir=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSConnect
    # How the agent should connect to server or proxy. Used for active checks.
    # Only one value can be specified:
    # unencrypted - connect without encryption
    # psk - connect using TLS and a pre-shared key
    # cert - connect using TLS and a certificate
    # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
    # Default:
    # TLSConnect=unencrypted
    ### Option: TLSAccept
    # What incoming connections to accept.
    # Multiple values can be specified, separated by comma:
    # unencrypted - accept connections without encryption
    # psk - accept connections secured with TLS and a pre-shared key
    # cert - accept connections secured with TLS and a certificate
    # Default:
    # TLSAccept=unencrypted
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSServerCertIssuer
    # Allowed server certificate issuer.
    # Mandatory: no
    # Default:
    # TLSServerCertIssuer=
    ### Option: TLSServerCertSubject
    # Allowed server certificate subject.
    # Mandatory: no
    # Default:
    # TLSServerCertSubject=
    ### Option: TLSCertFile
    # Full pathname of a file containing the agent certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    # Full pathname of a file containing the agent private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    ### Option: TLSPSKIdentity
    # Unique, case sensitive string used to identify the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKIdentity=
    ### Option: TLSPSKFile
    # Full pathname of a file containing the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKFile=
    ####### For advanced users - TLS ciphersuite selection criteria #######
    ### Option: TLSCipherCert13
    # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
    # Override the default ciphersuite selection criteria for certificate-based encryption.
    # Mandatory: no
    # Default:
    # TLSCipherCert13=
    # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
    # Example for GnuTLS:
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # Example for OpenSSL:
    # EECDH+aRSA+AES128:RSA+aRSA+AES128
    # Mandatory: no
    # Default:
    # TLSCipherCert=
    ### Option: TLSCipherPSK13
    # Override the default ciphersuite selection criteria for PSK-based encryption.
    # Example:
    # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
    # Mandatory: no
    # Default:
    # TLSCipherPSK13=
    # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
    # kECDHEPSK+AES128:kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherPSK=
    ### Option: TLSCipherAll13
    # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
    # Example:
    # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
    # Mandatory: no
    # Default:
    # TLSCipherAll13=
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherAll=
    ####### For advanced users - TCP-related fine-tuning parameters #######
    ## Option: ListenBacklog
    # The maximum number of pending connections in the queue. This parameter is passed to
    # listen() function as argument 'backlog' (see "man listen").
    # Mandatory: no
    # Range: 0 - INT_MAX (depends on system, too large values may be silently truncated to implementation-specified maximum)
    # Default: SOMAXCONN (hard-coded constant, depends on system)
    # ListenBacklog=
    //-----log-----//
    2832:20220916:082911.815 Starting Zabbix Agent [hostname]. Zabbix 5.4.4 (revision 1765c4f1bc).
    2832:20220916:082911.815 **** Enabled features ****
    2832:20220916:082911.815 IPv6 support: YES
    2832:20220916:082911.816 TLS support: NO
    2832:20220916:082911.816 **************************
    2832:20220916:082911.816 using configuration file: Path to conf file
    2832:20220916:082912.553 agent #0 started [main process]
    3204:20220916:082912.553 agent Home started [collector]
    3172:20220916:082912.554 agent #3 started[listener #2]
    5272:20220916:082912.554 agent Forum started[listener #1]
    8164:20220916:082912.555 agent #4 started[listener #3]
    8328:20220916:082912.555 agent #5 started [active checks #1]
    8328:20220916:082933.561 active check configuration update from [zabbix-server-ip:10051] started to fail (cannot connect to [[zabbix-server-ip]:10051]: A connection timeout occurred.)​
    Hostname and register are correct. A dont configure zabbix-server conf file. I tried many advices to another guys with similar troubles, but it useless. I dont have firewall or smth like that.
    Please, tell me some advices that can fix my problem. I think its a tiny trouble and i cant find it.
  • Answer selected by paw at 16-09-2022, 09:26.
    cyber
    • 4949
    Seems like network/firewall issues... You can try with plain telnet from host to server:10051, you should get somekind of connection.
      • 4949
      • paw
        • Sep 2022
        Thank u very much!
        I checked iptables, there no rules for 10050 and 10051. I added it and active agent worked.
        Have a good day!
