Hello, everybody,
I have a zabbix 3.0.1 running on centOS7 with 64GB RAM, 4x400GB SSD. I use the default DB schema at the beginning, then every went well. The NVPS is around 1200 after I imported 100+ hosts and the history syncer process is around 1%. However, I partitioned MySQL arounding to the guide https://www.zabbix.org/wiki/Docs/howto/mysql_partition, after which, I added another host. Then the history syncer process started to go as high as 50% busy, and I cannot get any data of the newly-added host during the busy window of history syner process. I have no idea what was going wrong, can anyone enlighten me?
/etc/my.cnf
datadir=/var/lib/mysql
socket=/var/lib/mysql/mysql.sock
max_connections = 2048
# Disabling symbolic-links is recommended to prevent assorted security risks
symbolic-links=0
innodb_file_per_table=1
innodb_buffer_pool_size = 40G
innodb_log_file_size=64M
innodb-flush-log-at-trx-commit = 0
log-error=/var/log/mysqld.log
pid-file=/var/run/mysqld/mysqld.pid
zabbix server configuration
CacheSize=2G
HistoryCacheSize=2G
HistoryIndexCacheSize=2G
TrendCacheSize=2G
ValueCacheSize=8G
Appreciate your advice very much.
/etc/my.cnf
symbolic-links=0
CacheSize=2G
HistoryCacheSize=2G
TrendCacheSize=2G
ValueCacheSize=8G
