Zabbix-get incomplete string
  • oxpy
    • Oct 2022
    Hello everybody. I have a problem with a receiving data from host to zabbix server. I have the script which make JSON format for zabbix server for discovery rules.
    #!/bin/bash
    TERM=linux
    while [ -n "$1" ]
    do
    case "$1" in​​
    -j) p="$2"
    g=$(top -Hbn1 | grep $p | awk '{print $NF}' ORS=',')
    IFS=$',' read -r -a customArray <<< $g
    echo -e "["
    for ((c=0; c<${#customArray[@]}; c++))
    do
    if ((c==$((${#customArray[@]}-1))));
    then
    echo -e "{"proc":"${customArray[c]}"}"
    else
    echo -e "{"proc":"${customArray[c]}"},"
    fi
    done
    echo -e "]"
    shift ;;​
    esac
    shift
    done​
    This script returns the following if execute it from host(agent):
    /zabbix_proc.sh -j kworker/85
    {"proc":"kworker/85:0H"},
    {"proc":"kworker/85:1H"},
    {"proc":"kworker/85:2"},
    {"proc":"kworker/85:0"}
    But when I doing the get request from zabbix server with this command:
    zabbix_get -s 172.16.164.72 -k di[kworker/85]
    I get the output:
    {"proc":"kworker/85+"},
    Here is incomplete value which ends "+". Everytime I have output limited to 10 symbols with every process which has more than 10 symbols
    My config file for zabbix-agent:
    UserParameter=di[*],/etc/zabbix/zabbix_proc.sh -j $1
    UnsafeUserParameters=1
    AllowKey=system.run[*]
    Help me please to understand it and I will be glad if you have a solution. Thank you
  • Answer selected by oxpy at 09-10-2022, 16:33.
    Markku
    • Sep 2018
    • 1784
    Looks like your top output lines are being truncated when run noninteractively. Try adding -w 200 (or some other value larger than 80 that maybe is the default), like top -Hbn1 -w 200
    Markku
    • oxpy
      oxpy commented
      You are right, it is works. Thank you.
      Also we can use another command:
      g=$(ps -e -T | grep $p | awk '{print $NF}' ORS=',')
  • Markku
    • Sep 2018
    • 1784
    Markku
    • oxpy
      oxpy commented
