How to disable PTR requests
  • GALA
    • Aug 2022
    • 13
    Hello
  • Markku
    • Sep 2018
    • 1784
    I don't have direct answer to you, but I know Zabbix implementations where a caching DNS resolver is running and used on the Zabbix server (only serving locally) just to decrease the number of DNS resolution requests that are sent out to the normal upstream resolvers.
    Markku
    • GALA
      GALA commented
      zabbix 6.2 in a container. all nodes are added by IP, there are no discovery rules.
      I don't understand why it goes to DNS and asks for PTR.
      I don't need to look up DNS by IP.
      How can I get him to stop doing it?
      It is very strange that there is no answer to this question at all, even in the communities....
  • Markku
    • Sep 2018
    • 1784
    Depending on your system you may also want to see systemd-resolved configuration.
    Markku
    • Markku
      • Sep 2018
      • 1784
      It is very strange that there is no answer to this question at all, even in the communities....​
      Oh there are existing discussions and support ticket(s) around this, AFAIK they all conclude that it is not Zabbix that does the lookups but it's the underlaying operating system. So you would need to find out a way to reconfigure your container if you want to change its behaviour. (You know how some say containers are easy way to deploy anything? They just skip the details...)
      Markku
      • GALA
        GALA commented
        Interesting, I'll try to find an answer. Thanks a lot , be healthy and happy
