I just upgraded to 6.4.0-beta1 using the ubuntu repository.
After a bunch of struggling, I finally got it to update the database and got primary keys added. Apparently in phpmyadmin adding or revoking the SUPER privilege on a user revokes all that user's per-database privileges. The server log said that it needed SUPER privilege to update the database.
Now that I can get back into the UI, I am finding that an important function seems to be gone. I believe the item in the UI I am used to clicking on is "Configuration" and then I would choose Hosts from that section. That is completely gone from the UI.
If I go to Inventory and choose Hosts, nothing is displayed.
I have a workaround available, but it is not straightforward. I can go to Monitoring, click Hosts, click on a hostname, and choose Inventory. Then I can access the things I would have gone to Configuration->Hosts to get to: Items, Triggers, Graphs, Discovery, Web.
Have I done something wrong? Is there a configuration change I should make to improve things? If my hosts were displayed when I click Inventory->Hosts, that would be enough.
