Zabbix Frontend 3 step Database type blank
  • Contreras
    • Oct 2022
    Hello, I am installing Zabbix 5 Centos 7, in step 3 i have this error:
    Packages installation and configuration worked fine
    ~]# rpm -qa | grep zabbix
    zabbix-get-5.0.28-1.el7.x86_64
    zabbix-web-deps-scl-5.0.28-1.el7.noarch
    zabbix-agent-5.0.28-1.el7.x86_64
    zabbix-web-mysql-scl-5.0.28-1.el7.noarch
    zabbix-server-mysql-5.0.28-1.el7.x86_64
    zabbix-web-5.0.28-1.el7.noarch
    zabbix-release-5.0-1.el7.noarch
    zabbix-apache-conf-scl-5.0.28-1.el7.noarch
    ##############################################3
    ~]# rpm -qa | grep php
    php-gd-7.2.34-13.el7.remi.x86_64
    rh-php72-php-bcmath-7.2.24-1.el7.x86_64
    rh-php72-1-2.el7.x86_64
    php-process-7.2.34-13.el7.remi.x86_64
    php-7.2.34-13.el7.remi.x86_64
    rh-php72-php-mysqlnd-7.2.24-1.el7.x86_64
    php-common-7.2.34-13.el7.remi.x86_64
    php-pdo-7.2.34-13.el7.remi.x86_64
    rh-php72-php-json-7.2.24-1.el7.x86_64
    php-pgsql-7.2.34-13.el7.remi.x86_64
    rh-php72-php-ldap-7.2.24-1.el7.x86_64
    rh-php72-php-gd-7.2.24-1.el7.x86_64
    rh-php72-php-process-7.2.24-1.el7.x86_64
    php-mysqlnd-7.2.34-13.el7.remi.x86_64
    rh-php72-php-common-7.2.24-1.el7.x86_64
    php-ldap-7.2.34-13.el7.remi.x86_64
    rh-php72-php-pgsql-7.2.24-1.el7.x86_64
    rh-php72-php-xml-7.2.24-1.el7.x86_64
    php-cli-7.2.34-13.el7.remi.x86_64
    oniguruma5php-6.9.7.1-1.el7.remi.x86_64
    rh-php72-runtime-1-2.el7.x86_64
    rh-php72-php-pdo-7.2.24-1.el7.x86_64
    rh-php72-php-fpm-7.2.24-1.el7.x86_64
    rh-php72-php-cli-7.2.24-1.el7.x86_64
    php-json-7.2.34-13.el7.remi.x86_64
    rh-php72-php-zip-7.2.24-1.el7.x86_64
    php-mbstring-7.2.34-13.el7.remi.x86_64
    rh-php72-php-mbstring-7.2.24-1.el7.x86_64
    rh-php72-php-pear-1.10.5-1.el7.noarch
    php-pecl-mysql-1.0.0-0.17.20160812git230a828.el7.remi.7.2.x86_64
    gd3php-2.3.3-6.el7.remi.x86_64
    log file
    20512:20221012:101736.797 Got signal [signal:15(SIGTERM),sender_pid:13751,sender_uid:0,r eason:0]. Exiting ...
    20532:20221012:101736.799 syncing history data in progress...
    20532:20221012:101736.799 syncing history data done
    20512:20221012:101736.824 syncing trend data...
    20512:20221012:101736.878 syncing trend data done
    20512:20221012:101736.878 Zabbix Server stopped. Zabbix 5.0.28 (revision b2b8e2ce82d).
    13888:20221012:101738.929 Starting Zabbix Server. Zabbix 5.0.28 (revision b2b8e2ce82d).
    13888:20221012:101738.929 ****** Enabled features ******
    13888:20221012:101738.929 SNMP monitoring: YES
    13888:20221012:101738.929 IPMI monitoring: YES
    13888:20221012:101738.929 Web monitoring: YES
    13888:20221012:101738.929 VMware monitoring: YES
    13888:20221012:101738.929 SMTP authentication: YES
    13888:20221012:101738.929 ODBC: YES
    13888:20221012:101738.929 SSH support: YES
    13888:20221012:101738.929 IPv6 support: YES
    13888:20221012:101738.929 TLS support: YES
    13888:20221012:101738.929 ******************************
    13888:20221012:101738.929 using configuration file: /etc/zabbix/zabbix_server.conf
    13888:20221012:101738.936 current database version (mandatory/optional): 05000000/05000007
    13888:20221012:101738.936 required mandatory version: 05000000
    13888:20221012:101738.944 server #0 started [main process]
    13892:20221012:101738.945 server Home started [configuration syncer #1]
    13920:20221012:101739.056 server Auf Deutsch started [poller #5]
    13922:20221012:101739.058 server Zabbix for Large Environments started [trapper #1]
    13928:20221012:101739.059 server check_port in Win32 started [alert syncer #1]
    13925:20221012:101739.059 server 中文论坛 started [trapper #4]
    13904:20221012:101739.061 server #13 started [housekeeper #1]
    13906:20221012:101739.061 server General started [http poller #1]
    13907:20221012:101739.061 server Zabbix Discussions and Feedback started [discoverer #1]
    13909:20221012:101739.063 server Zabbix in Your Language started [history syncer #2]
    13912:20221012:101739.063 server Zabbix Troubleshooting and Problems started [escalator #1]
    13915:20221012:101739.065 server Zabbix Feedback for alpha and beta versions started [task manager #1]
    13916:20221012:101739.065 server Zabbix Cookbook started [poller #1]
    13924:20221012:101739.067 server En français started [trapper #3]
    13926:20221012:101739.069 server ZABBIX forum operates in test mode started [trapper #5]
    13905:20221012:101739.070 server Zabbix Announcements started [timer #1]
    13901:20221012:101739.071 server #10 started [lld manager #1]
    13914:20221012:101739.071 server Site feedback started [self-monitoring #1]
    13927:20221012:101739.071 server I Love the new forums! started [icmp pinger #1]
    13923:20221012:101739.072 server In lingua italiana started [trapper #2]
    13897:20221012:101739.074 server Special started [preprocessing manager #1]
    13917:20221012:101739.074 server Zabbix Patches started [poller #2]
    13893:20221012:101739.076 server Forum started [alert manager #1]
    13894:20221012:101739.076 server #3 started [alerter #1]
    13895:20221012:101739.076 server #4 started [alerter #2]
    13898:20221012:101739.076 server #7 started [preprocessing worker #1]
    13899:20221012:101739.077 server Private Messages started [preprocessing worker #2]
    13900:20221012:101739.077 server Albums started [preprocessing worker #3]
    13903:20221012:101739.077 server CSS Examples started [lld worker #2]
    13908:20221012:101739.077 server Zabbix (alpha, beta) Discussions and Feedback started [history syncer #1]
    13910:20221012:101739.078 server Zabbix Announcements started [history syncer #3]
    13913:20221012:101739.078 server Zabbix Help started [proxy poller #1]
    13918:20221012:101739.080 server Off-topic discussion started [poller #3]
    13919:20221012:101739.081 server На русском языке started [poller #4]
    13921:20221012:101739.083 server Em Português y En Español started [unreachable poller #1]
    13896:20221012:101739.085 server #5 started [alerter #3]
    13902:20221012:101739.085 server #11 started [lld worker #1]
    13911:20221012:101739.085 server Zabbix Suggestions and Feedback started [history syncer #4]
    Would you help me please?
  • Atsushi
    • Aug 2013
    • 2028
    Zabbix 5.0 web frontend package for RHEL 7 in Zabbix official repository is configured using SCL. It seems that you have also installed remi's PHP package, how did you configure PHP to work with Apache HTTP Server? Check if anything is output to the web server or PHP related logs.
    • Ricardo55E
      • Oct 2022
      Thanks for sharing. I found a lot of interesting information here.
