Fake Resolved for disk utilization
  • ZeroOnePL
    • Apr 2022
    • 12
    Hi, I use Zabbix 6.2.3
    I use default built-in template to "windows zabbix filesystem active"
    I have problem bcs they fake resolved disk utlization status.
    Disk incrasce but i have notification about its fake and resolved .
    • 5004
    Things are on your screen, but you are not reading it... "Two conditions should match:" one is about actual free space. Other is about filling up speed... So if only one is fulfilled, trigger fill not fire... Or it resolves..
    • ZeroOnePL
      • Apr 2022
      • 12
      Speed? what speed?
      First is condition is about percent utlization
      second is about free space is less then ....
      So what can i do?
        • 5004
        Again its written on your screenshots...
        second one is "one of following"
        disk space less than 10000M (which is 10G, so in this case not true, you seem to have ~75G there empty).
        or
        disk will be filled up in next 24h...
        I suppose based on data (growth rate) it will not be filled up in next 24h... Thus turning trigger to resolved...
        Maybe you have there something intermittently writing a bigger chunk of data to disk, which upsets the calculation, making it think, that if it continues like this, then we'll be out of room before 24h...
        • ZeroOnePL
          • Apr 2022
          • 12
          Ok so how can i change this to run trigger only with one condition or two or three. Not only with 2.
            • 5004
            Deep dive into trigger prototype config and change it as you need...
