XML Template Import Failure
  • rdineen
    • Oct 2022
    Hi Everyone!
    I've recently installed Zabbix 6.2 and have some Avaya/Extreme ERS3650 switches that I'm trying to monitor via SNMP.
    I've found the MIBs from the Extreme portal and created a template using the mib2zabbix Perl script and am running into an issue importing.
    I'm receiving the following error when trying to import the template:
    Access denied
    • You are logged in as "Admin". You have no permissions to access this page.
    • If you think this message is wrong, please consult your administrators about getting the necessary permissions.
    I've given the Super Admin group RW permissions to all templates and hosts and also created another user and user group with RW permissions to templates and hosts (and everything else I can see) with no change.
    Prior to running the mib2zabbix script I was using a template generated from the Monitoring Artist's webapp and only received errors about missing/unexpected tags which I am no longer getting with the mib2zabbix XML file.
    I'm not sure how the data is processed after hitting import so I'm not sure where to look next.
    I'm brand new to Zabbix but not to monitoring apps (Nagios/PRTG) and Linux so I'm not sure where I went wrong.
    Any help (or docs I missed) is greatly appreciated!
