Discovery item as Zabbix trapper thru Proxy - not work...
  • ceinmart
    • Nov 2012
    • 28
    Hi ,
    I have set my zabbix Server and Proxy on linux , both versions 6.2.0
    For few hosts monitored thru this Proxy , I need to use Zabbix trapper for most of the items.
    Now I'm trying to configure a Discovery rule item, based on Zabbix Trapper item.
    However , appear that configuration do not work.
    The zabbix_sender, always failed.
    I'm not sure if this is a issue with Proxy or if the Zabbix really doesn't support Discovery rule items as "Zabbix trapper" and the this should be corrected at the frontend.
    I already restarted the server, the proxy, forced the cache reload.
    Enabling more verbose logging on the Proxy , I get this message when I send the data with zabbix_sender:
    1315:20221021:081953.991 cannot retrieve key "alertfile_discovery" on host "xxxxx" from configuration cache
    ​Anyone have any experience over this situation ? Is this a bug ? or I'm doing something wrong ?
  • Answer selected by ceinmart at 25-10-2022, 20:14.
    ceinmart
    • Nov 2012
    • 28
    SOLVED...
    Sorry guys... my mistake.
    Typo issue on the hostname !!!!
    • Markku
      • Sep 2018
      • 1784
      Can you show the contents of that data you sent as trapper item? Is it valid LLD JSON?
      Markku
      • ceinmart
        • Nov 2012
        • 28
        Hi ,
        Sorry the delay.
        I'm using this sender command + this test file :
        $ zabbix_sender -vv -T -i x.txt -c /etc/zabbix/zabbix_agentd.conf
        $ cat x.txt
        hostabc alertfile_discovery 1666720846 {"{#ALERTFILE}":"/oracle/diag/rdbms/xxx/xxxx/trace/alert_xxxx.log"}
        • ceinmart
          • Nov 2012
          • 28
          SOLVED...
