Cisco Template and VLans
  • wiliamL
    • Feb 2022
    • 28
    Does anyone have a cisco template that ignores bandwidth issues on VLANS? OR guidance in how to have it ignore these?
    ​thank you in advance
  • Markku
    • Sep 2018
    • 1784
    You can use LLD override to prevent trigger prototype from being created for interfaces that meet your criteria. Documentation: https://www.zabbix.com/documentation...overy#override
    Or, you can just manually disable all the vlan interfaces after the discovery has happened, they won't be enabled automatically again.
    Markku
    • wiliamL
      • Feb 2022
      • 28
      I created an override that creates the trigger but disables it. Thanks for the info.
