Upgrade Issues to 3.0.1
  • tomtomclub
    • Oct 2013
    • 9
    I'm running Zabbix 2.0.9 and trying to upgrade to 3.0.1, which according to the installation instructions is possible as a direct upgrade. So, I followed the instructions to install the 3.0 repo by running:
    When I then try and update zabbix I get errors like this:
    Error: Package: zabbix-server-mysql-2.0.9-1.el6.x86_64 (@zabbix)
    Requires: zabbix = 2.0.9-1.el6
    Removing: zabbix-2.0.9-1.el6.x86_64 (@zabbix)
    Obsoleted By: zabbix-proxy-mysql-3.0.1-1.el6.x86_64 (zabbix)
    Not found
    Available: zabbix-1.8.22-1.el6.x86_64 (epel)
    zabbix = 1.8.22-1.el6
    Available: zabbix22-2.2.11-1.el6.x86_64 (epel)
    zabbix = 2.2.11-1.el6
    My /etc/yum.repos.d/zabbix.repo file has the right info:
    [zabbix]
    name=Zabbix Official Repository - $basearch
    baseurl=http://repo.zabbix.com/zabbix/3.0/rhel/6/x86_64/
    enabled=1
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX
    So it seems like I'm in a weird place where 2.0 is installed
    Installed Packages
    zabbix.x86_64 2.0.9-1.el6 @zabbix
    and instead of seeing the 3.0 repo files the upgrade process sees the files available in the epel repo for Zabbix
    repoquery -qi zabbix
    Version : 1.8.22
    Release : 1.el6
    Architecture: x86_64
    Packager : Fedora Project
    Group : Applications/Internet
    URL : http://www.zabbix.com
    Repository : epel
    Summary : Open-source monitoring solution for your IT infrastructure
    Source : zabbix-1.8.22-1.el6.src.rpm
    and not the new zabbix.repo file I have, even if I disable the epel repo
    yum --disablerepo="*" --enablerepo="zabbix" list zabbix
    Loaded plugins: fastestmirror, security
    Loading mirror speeds from cached hostfile
    * base: mirror.es.its.nyu.edu
    * extras: mirror.es.its.nyu.edu
    * updates: centos.mirror.nac.net
    Installed Packages
    I appear to be in some sort of repo hell, and the core issue seems to be that I can't get yum to see the new zabbix.repo file. Can anyone provide assistance, point me in the right direction, etc.?
  • jan.garaj
    • Jan 2010
    • 506
    Try to clean your os package cache (yum clean all is not sufficient command in some cases).
