Elasticsearch Issues with Trapper data
  • mdiorio
    • Mar 2016
    • 27
    If I can get this to work, this is the best use for Zabbix and Elastic monitoring.
    I get Zabbix agent results back for master_node and cluster health status, but none of the Zabbix Trapper items are returning any data.
    In the es_stats_zabbix.log I'm seeing the following:
     2016-03-28 11:21:22,202 DEBUG es_stats_zabbix batch:131 Batch mode with named batch: thirty_seconds
     2016-03-28 11:21:22,203 DEBUG es_stats_zabbix batch:137 Batch config args: {'key3': 'health[initializing_shards]', 'key2': 'health[relocating_shards]', 'key1': 'health[unassigned_shards]', 'server': 'ghq-1pmonap01.globalspec.net', 'host': 'ghq-1delasticnode01.globalspec.net', 'key4': 'health[delayed_unassigned_shards]', 'port': '10051'}
     2016-03-28 11:21:22,203 DEBUG es_stats_zabbix batch:143 Batch keys: {'key3': 'health[initializing_shards]', 'key2': 'health[relocating_shards]', 'key1': 'health[unassigned_shards]', 'key4': 'health[delayed_unassigned_shards]'}
     2016-03-28 11:21:22,204 DEBUG es_stats_zabbix.utils parse_key:142 API: health Node: None Key: initializing_shards
     2016-03-28 11:21:22,204 DEBUG es_stats_zabbix.utils parse_key:142 API: health Node: None Key: relocating_shards
     2016-03-28 11:21:22,204 DEBUG es_stats_zabbix.utils parse_key:142 API: health Node: None Key: unassigned_shards
     2016-03-28 11:21:22,204 DEBUG es_stats_zabbix.utils parse_key:142 API: health Node: None Key: delayed_unassigned_shards
     2016-03-28 11:21:22,204 DEBUG es_stats_zabbix batch:150 API-separated keys: {'nodeinfo': [], 'clusterstate': [], 'health': [('health', None, 'initializing_shards'), ('health', None, 'relocating_shards'), ('health', None, 'unassigned_shards'), ('health', None, 'delayed_unassigned_shards')], 'nodestats': [], 'clusterstats': []}
     2016-03-28 11:21:22,205 DEBUG urllib3.util.retry from_int:155 Converted retries value: False -> Retry(total=False, connect=None, read=None, redirect=0)
     2016-03-28 11:21:22,208 DEBUG urllib3.connectionpool _make_request:383 "GET /_cluster/health HTTP/1.1" 200 390
     2016-03-28 11:21:22,208 INFO elasticsearch log_request_success:63 GET http://127.0.0.1:9200/_cluster/health [status:200 request:0.003s]
     2016-03-28 11:21:22,209 DEBUG elasticsearch log_request_success:65 > None
     2016-03-28 11:21:22,209 DEBUG elasticsearch log_request_success:66 < {"cluster_name":"artemis_dev","status":"yellow","timed_out":false,"number_of_nodes":1,"number_of_data_nodes":1,"active_primary_shards":62,"active_shards":62,"relocating_shards":0,"initializing_shards":0,"unassigned_shards":62,"delayed_unassigned_shards":0,"number_of_pending_tasks":0,"number_of_in_flight_fetch":0,"task_max_waiting_in_queue_millis":0,"active_shards_percent_as_number":50.0}
     2016-03-28 11:21:22,210 DEBUG es_stats_zabbix batch:165 Metrics: [Metric('ghq-1delasticnode01.globalspec.net', 'health[initializing_shards]', 0), Metric('ghq-1delasticnode01.globalspec.net', 'health[relocating_shards]', 0), Metric('ghq-1delasticnode01.globalspec.net', 'health[unassigned_shards]', 62), Metric('ghq-1delasticnode01.globalspec.net', 'health[delayed_unassigned_shards]', 0)]
     **2016-03-28 11:21:22,214 DEBUG zbxsender send_to_zabbix:58 Got response from Zabbix: {u'info': u'processed: 0; failed: 4; total: 4; seconds spent: 0.000018', u'response': u'success'}
     2016-03-28 11:21:22,214 INFO zbxsender send_to_zabbix:59 processed: 0; failed: 4; total: 4; seconds spent: 0.000018
     **2016-03-28 11:21:22,214 DEBUG es_stats_zabbix batch:167 Result = True
     2016-03-28 11:21:22,215 INFO es_stats_zabbix batch:170 Job completed.
    In zabbix server log set to debug, I do see:
    9185:20160328:112635.725 __zbx_zbx_setproctitle() title:'trapper #4 [processing data]'
     9185:20160328:112635.725 trapper got '{
     "request":"sender data",
     "data":[
     "host":"ghq-1delasticnode01.globalspec.net",
     "key":"health[initializing_shards]",
     "value":0,
     "clock":1459178782.36},
     "key":"health[relocating_shards]",
     "value":0,
     "key":"health[unassigned_shards]",
     "value":62,
     "key":"health[delayed_unassigned_shards]",
     "value":0,
     "clock":1459178782.36}]
    Which tells me that it's getting the data, but when I view the last data for the host, there is no data there.
    Any ideas? I've only been using Zabbix for two weeks as I'm evaluating new monitoring solutions, and this is really my first major hurdle for it.
    Thanks.
    Zabbix Version 3.0.1
    es_stats_zabbix version: 0.1.3
    Elasticsearch version: 2.2.0
  • kloczek
    • Jun 2006
    • 1771
    Do you have in list of registered hosts ghq-1delasticnode01.globalspec.net and/or in list of monitored items on this host item with health[initializing_shards] and other key definition as "zabbix trapper" items?
    • mdiorio
      • Mar 2016
      • 27
      Sure do. Monitors using zabbix agent on the elastic node host return data successfully. It's only the zabbix trapper items that don't contain data.
      • blackspiraldancer
        • Nov 2016
        Same exact behavior here. Single checks are OK, but no trapping.
        • urusha
          • Feb 2017
          fix
          Python zbxsend uses non-integer timestamp, which zabbix-server doesn't accept.
          One way to fix this is changing
          clock
          to
          int(clock)
          in
          metrics_data.append
          in zbxsend.py
          Here is the issue about it: https://github.com/pistolero/zbxsend/issues/12
