New Zabbix installation problem with mysql
  • ALav80
    • Oct 2022
    I saw this problem a lot in forums, but still cannot solve it for some reason. I have a fresh install on Centos 9, I can connect to mysql with zabbix user:
    mysql -uzabbix -ppassword zabbix
    Created all tables and everything needed,
    This is my /etc/zabbix/zabbix_server.conf:
    DBName=zabbix
    DBUser=zabbix
    DBPassword=password
    But when I start Zabbix, I see this in logs:
    67807:20221031:140124.467 using configuration file: /etc/zabbix/zabbix_server.conf
    31487:20221031:140132.619 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
    31487:20221031:140132.619 database is down: reconnecting in 10 seconds
    What am I missing?
    thank you in advance.
  • netai
    • Nov 2022
    Hi, I think the problem is related to authorizing remote connections.
    Login into mysql console and run this code (be awere to check the correct syntax):
    GRANT ALL PRIVILEGES ON *.* TO 'zabbix'@'%' IDENTIFIED BY 'zabbix' WITH GRANT OPTION;
    FLUSH PRIVILEGES;​
