zabbix-db container starts and then stops
  • phial63
    • Nov 2022
    Hello
    I have inherited the management of a Zabbix installation on a Synology box using docker and it has been operating without issue for years. After a recent reboot, the zabbix-db container starts and then stops. I can't get it to run at all.
    The container log file seems to indicate an issue related to "Access denied for user 'root'@'127.0.0.1' (using password: NO)".
    The last successful start up shows the following lines in the container log:
    The 'root' user has no password but only allows local connections
    " For security reasons, you might want to change the above password.
    mysql -uzabbix -pXXXXXXX -h<host>
    You can now connect to this MariaDB Server using:
    "=> User 'zabbix' exists, updating its password to 'XXXXXXX'
    The person who set this up has left on bad terms and there is no documentation at all.
    Have trawled the forums but can't see anything close to this issue.
    Any assistance appreciated.
    Regards, Phil
