Usage of SNMP LLD Macros not possible in Discovery Trigger expressions
  • herr
    • Oct 2022
    I am trying to write a trigger that fires when an Interface on a switch goes down. Since I only want it to fire on certain interfaces, I've written a conditional that is supposed to evaluate to TRUE only when {#IFALIAS} has certain values. I am using the regexp() function to evaluate that. However, while this method does work on another trigger that uses a LLD Macro defined in the LLD Macros tab in the Discovery rule, it doesn't seem to evaluate at all when using a LLD Macro defined via SNMP OIDs. In fact, it doesn't even matter if I evaluate against anything (.*) OR negate the result. It seems as though the entire conditional silently fails.
    The expression I use is the following:
    avg(/HP CX Switch SNMP/net.if.status[ifOperStatus.{#SNMPINDEX}],2m)=2 and {{#IFALIAS}.regexp("{$NET.IF.IFALIAS.WATCHED}")}=1
    The {$NET.IF.IFALIAS.WATCHED} Macro is a regular expression definable at the host or template level. Again, it doesn't even matter whether I replace it with something like ".*". And like I said, in another template "{IFALIAS}" (with a different name of course) is defined via a JSONPath variable in the LLD Macro tab.
    Any help getting this trigger to run correctly is much appreciated.
  • Markku
    • Sep 2018
    • 1784
    See LLD overrides: https://www.zabbix.com/documentation...overy#override
    That will enable you to prevent creating triggers for interfaces that match your conditions.
    Markku
    • herr
      • Oct 2022
      Ahh thanks. I finally managed to achieve this by way of these overrides. Pretty convoluted, if you ask me. And I had to re-create the hosts to actually achieve what I had in mind. But thanks nonetheless!
