Solution to Azure SAML - Please rectify in code
  • Mallen
    • Dec 2019
    Hi guys,
    For a long time now Zabbix has had an issue with SAML when using Azure. This issue only seems to accur when using MS Edge if you are logged in to the same Microsoft account with Edge Profile. Issue relating to requestedAuthnContext. If I ling via Inprivate or a different profile in Edge, there is no issues.
    There was an easy solution in Zabbix 5.x that seems to have been broken in 6 and 6.2. In 5 I added
    $SSO['SETTINGS'] = ['requestedAuthnContext' => false];
    to /etc/zabbix/web/zabbix.conf.php. V6 this doesn't seem to do anything.
    Now in v6.2 I change in file /usr/share/zabbix/vendor/onelogin/php-saml/src/Saml2/Settings.php:
    if (!isset($this->_security['requestedAuthnContext'])) {
    $this->_security['requestedAuthnContext'] = true;
    to:
    $this->_security['requestedAuthnContext'] = false;
    This fixes the issue, but I think this file is not protected from upgrades as I have had to change a few times.
    Would be awesome to add a tickbox to the SAML settings that disabled this setting and protected against upgrades. ​​​
  • Markku
    • Sep 2018
    • 1790
    See this post, there the syntax of the PHP code is different: https://www.zabbix.com/forum/zabbix-...802#post437802
    'security' => [
    Markku
    Last edited by Markku; 08-11-2022, 07:29. Reason: Included the code in this post as well
    • Mallen
      • Dec 2019
      This appears to solve the issue. Thanks for that. Would be good if a checkbox in GUI but as long as there is a permanent solution, its not really a priority. Thanks again.
      • drwolcot
        • Aug 2023
        I am still running into this issue. I am running zabbix in docker and modified the .env_web file for the variable ZBX_SS_SETTINGS
        The only modification I have made to this is for the security fields.
        ZBX_SSO_SETTINGS={{"strict":false, "baseurl":"https://zabbix.domain.com/", "use_proxy_headers":true, "security":{"requestedAuthnContext":"false"}}
        I am now getting this login error
        [CODE]AADSTS7500524: No saml:AuthnContextClassRef or saml:AuthnContextDeclRefs elements were found within samlp:RequestedAuthnContext.[CODE]
        • Neelan29
          • Jul 2024
          drwolcot were you able to solve the error ^^ ??
          Im running into same error. using docker 6.4. Trying to integrate fido auth.
          Tried :
          ZBX_SSO_SETTINGS={{"strict":false, "baseurl":"https://zabbix.domain.com/", "use_proxy_headers":true, "security":{"requestedAuthnContext":"urn:oasis:names:tc:SAML:2.0:ac:classes:unspecified"}}
          • Neelan29
            • Jul 2024
            solved.
            workaround -> edit file
            vendor/onelogin/php-saml/src/Saml2/AuthnRequest.php
            replace
            urn:oasis:names:tc:SAML:2.0:ac:classes:PasswordProtectedTransport
            with
            • anslu
              • Aug 2023
              • 30
              No luck with version 7. Anyone has found a workaround?
              • rsokolovs
                • Nov 2024
                Had this isse with Zabbix 7.0.6 and resolved in /etc/zabbix/web/zabbix.conf.php file with:
                    'security' => [
                • anslu
                  • Aug 2023
                  • 30
                  'security' => [
                  Thank you!
                  • frank108
                    • Mar 2022
                    • 15
                    'security' => [
                    Thanks a lot, it works on 7.2 as well.
                    As I have a reverse proxy in front, I have this together:
                    PHP Code:
                    'use_proxy_headers' => true,
                    'security' => [
                    • CristiRo
                      • May 2025
                      'security' => [
                      I confirm i have done the same change in version 7.4.6 and is working fine with Azure application configured as SAML
                      Kudos rsokolovs!
