Zabbix LLD error about not discovered item.
  • Raido
    • Jun 2019
    • 13
    Current setup:
    Agent discovery contains following JSON:
    zabbix_agentd -t test.discovery
    test.discovery                                [t|{"data":[{"{#HWSN}":"Hardware serial number", "{#DEBVER}":"Debian OS version"}]}]​
    Template contains following item prototypes:
    Click image for larger versionName:	image.pngViews:	0Size:	138.7 KBID:	454385​
    But host gets discovery errors about the items that are not in agent discovery json:
    Cannot create item: item with the same key "test.monitor[{#NETSTATUS}]" already exists.
    Click image for larger version  Name:	image.png Views:	0 Size:	90.4 KB ID:	454386
    Why is that error displayed about non discovered items?​
    Server: Zabbix 6.0.8
    Agent: 5.0.15
  • Singularity
    • Aug 2020
    • 81
    For every item created using lld, the key should be unique which is not the case here. You need to check the key in item prototype.
    • Raido
      • Jun 2019
      • 13
      Can you explain a bit, where I am missing the uniqueness of the item key?
      • Singularity
        • Aug 2020
        • 81
        There is more than 1 item for each NETTYPE, NETSTATUS and NETTYPEPRIM.
        Zabbix should have created 1 item for each NETTYPE, NETSTATUS and NETTYPEPRIM with the keys you mentioned. ( check the items list )
        Zabbix is again trying to create item for each NETTYPE, NETSTATUS and NETTYPEPRIM but the keys already exist. Which is the reason you are getting the errors.
        Example : There are 2 disks
        1. Zabbix creates item for disk 1 with a key
        2. Zabbix creates item for disk 2 with same key mentioned in point 1. And it fails to do so
        The conclusion is, the key name should be dynamic. Hope this helps
        • Raido
          • Jun 2019
          • 13
          So I should change item keys like this?:
            • 4996
            Your discovery seems to return values for only 2 LLD macros... {#HWSN} and {#DEBVER} ... Where do the others appear? NETTYPE, NETSTATUS and NETTYPEPRIM. ? If they are not part of discovery, they are taken literally, so you will get errors about duplicate keys.
            • Raido
              • Jun 2019
              • 13
              Ah I see.
              In my mind, I am building something like this.
              Theres a script in all agent machine that generates discovery JSON based on script detections.
              Basically discovery JSON varies between different machines.
              host 1 json: [t|{"data":[{"{#HWSN}":"Hardware serial number", "{#DEBVER}":"Debian OS version"}]}]​
              host 2 json: [t|{"data":[{"{#HWSN}":"Hardware serial number"]}]​
              host 3 json: [t|{"data":[{ "{#DEBVER}":"Debian OS version"}]}]​
              and so on.
              All host use same template which has all those json values as items prototypes.
              Then zabbix assigns these hosts items to monitor based on discovery json.
              So like a one template fits all kind of situation.
                • 4996
                Dig into Discovery overrides. You may need to "not discover" things, if some stuff is missing..
