Zabbix not upgrading ( it looks like the repository is not being installed)
  • raphacravo
    • Nov 2022
    I'm trying to upgrade from zabbix 4.4 to zabbix 6, running on ubuntu 18, using this guide
    But i'm having this error when try to do the
    apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    zabbix-server-mysql is already the newest version (1:4.4.0-1+bionic).
    zabbix-agent is already the newest version (1:4.4.0-1+bionic).
    zabbix-frontend-php is already the newest version (1:4.4.0-1+bionic).
    I did the steps to install the zabbix 6 repository for ubuntu 18 (a lot of times) with no errors
    <code>
    ​# wget https://repo.zabbix.com/zabbix/6.2/u...u18.04_all.deb
    # dpkg -i zabbix-release_6.2-1+ubuntu18.04_all.deb
    # apt-get update
    </code>
    I don't know why the OS is not reading the zabbix 6 repository, and the OS is considering the zabbix 4 as up to date (I'm not a linux expert)
    Looking in my /etc/apt sources I didn't find anything related to zabbix. maybe I need to add repositories manually? The weird thing is that I can't see any errors doing the step of adding zabbix 6 repo with the .deb package.
  • Markku
    • Sep 2018
    • 1788
    You are using the repository for 6.2, not 6.0. There is no Zabbix server 6.2 for Ubuntu 18.04.
    Either use Zabbix 6.0 (see https://www.zabbix.com/download) or install Zabbix 6.2 server on a newer platform.
    Markku
      • 5004
      6.0 wont also install on 18.04 ... Need at least 20.04...
      • beriapl
        • Jun 2020
        I've ran into similiar issue on debian 10.13
        Package with repo is installing, but no repo entry in sources file:
        root@pve-07-07:~# dpkg -i zabbix-release_6.2-4+debian10_all.deb
        (Reading database ... 101847 files and directories currently installed.)
        Preparing to unpack zabbix-release_6.2-4+debian10_all.deb ...
        Unpacking zabbix-release (1:6.2-4+debian10) over (1:6.2-4+debian10) ...
        Setting up zabbix-release (1:6.2-4+debian10) ...
        root@pve-07-07:~# ls -al /etc/apt/sources.list.d/
        total 16
        drwxr-xr-x 2 root root 4096 Jan 18 00:38 .
        drwxr-xr-x 7 root root 4096 Aug 12 2021 ..
        -rw-r--r-- 1 root root 64 Dec 5 2021 ceph.list
        -rw-r--r-- 1 root root 76 Jan 18 2022 linux.dell.com.sources.list
        root@pve-07-07:~# apt update
        Hit:1 http://ftp.pl.debian.org/debian buster InRelease
        Get:2 http://ftp.pl.debian.org/debian buster-updates InRelease [56.6 kB]
        Hit:3 http://security.debian.org buster/updates InRelease
        Hit:4 http://download.proxmox.com/debian/pve buster InRelease
        Hit:5 http://download.proxmox.com/debian/ceph-octopus buster InRelease
        Fetched 56.6 kB in 2s (37.7 kB/s)
        Reading package lists... Done
        Building dependency tree
        Reading state information... Done
        3 packages can be upgraded. Run 'apt list --upgradable' to see them.
        root@pve-07-07:~# apt list --upgradable
        Listing... Done
        libsnmp-base/oldstable 5.7.3+dfsg-5+deb10u4 all [upgradable from: 5.7.3+dfsg-5+deb10u3]
        libsnmp30/oldstable 5.7.3+dfsg-5+deb10u4 amd64 [upgradable from: 5.7.3+dfsg-5+deb10u3]
        libtasn1-6/oldstable 4.13-3+deb10u1 amd64 [upgradable from: 4.13-3]
        • Markku
          • Sep 2018
          • 1788
          Strange, never seen the file missing.
          What does it say if you add -D33 in the dpkg install command?
          Markku
          • DarwinXNU
            • Dec 2014
            I'm also seeing this issue while trying to update from 5.0 to 6.0 on Debian 10 using the upgrade guide.
            root@zabbix:~# dpkg -D33 -i zabbix-release_latest+debian10_all.deb
            D000001: ensure_diversions: new, (re)loading
            D000001: ensure_statoverrides: new, (re)loading
            D000010: path_remove_tree '/var/lib/dpkg/tmp.ci'
            (Reading database ... 58787 files and directories currently installed.)
            Preparing to unpack zabbix-release_latest+debian10_all.deb ...
            D000020: process_archive conffile '/etc/apt/sources.list.d/zabbix-agent2-plugins.list' package=zabbix-release:all same hash=ebf47c52e6c7c6ee8650b1bf7c565f77
            D000020: process_archive conffile '/etc/apt/sources.list.d/zabbix.list' package=zabbix-release:all same hash=4c1682d9d182caed416401d12e26d3c5
            D000020: process_archive conffile '/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg' package=zabbix-release:all same hash=c59dbe08aff7e91d2cc694ca178909ac
            D000001: process_archive oldversionstatus=installed
            D000002: maintscript_fallback nonexistent prerm '/var/lib/dpkg/info/zabbix-release.prerm'
            D000002: maintscript_new nonexistent preinst '/var/lib/dpkg/tmp.ci/preinst'
            Unpacking zabbix-release (1:6.0-4+debian10) over (1:6.0-4+debian10) ...
            D000010: tarobject ti->name='.' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/.' flags=2 instead='<none>'
            D000010: tarobject ti->name='./etc' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/etc' flags=2 instead='<none>'
            D000010: tarobject ti->name='./etc/apt' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/etc/apt' flags=2 instead='<none>'
            D000010: tarobject ti->name='./etc/apt/sources.list.d' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/etc/apt/sources.list.d' flags=2 instead='<none>'
            D000010: tarobject ti->name='./etc/apt/sources.list.d/zabbix-agent2-plugins.list' mode=100755 owner=0:0 type=48(-) ti->linkname='' namenode='/etc/apt/sources.list.d/zabbix-agent2-plugins.list' flags=7 instead='<none>'
            D000020: tarobject FNNF_NEW_CONFF deref='/etc/apt/sources.list.d/zabbix-agent2-plugins.list'
            D000010: path_remove_tree '/etc/apt/sources.list.d/zabbix-agent2-plugins.list.dpkg-new'
            D000010: path_remove_tree '/etc/apt/sources.list.d/zabbix-agent2-plugins.list.dpkg-tmp'
            D000010: tarobject ti->name='./etc/apt/sources.list.d/zabbix.list' mode=100755 owner=0:0 type=48(-) ti->linkname='' namenode='/etc/apt/sources.list.d/zabbix.list' flags=7 instead='<none>'
            D000020: tarobject FNNF_NEW_CONFF deref='/etc/apt/sources.list.d/zabbix.list'
            D000010: path_remove_tree '/etc/apt/sources.list.d/zabbix.list.dpkg-new'
            D000010: path_remove_tree '/etc/apt/sources.list.d/zabbix.list.dpkg-tmp'
            D000010: tarobject ti->name='./etc/apt/trusted.gpg.d' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/etc/apt/trusted.gpg.d' flags=2 instead='<none>'
            D000010: tarobject ti->name='./etc/apt/trusted.gpg.d/zabbix-official-repo.gpg' mode=100755 owner=0:0 type=48(-) ti->linkname='' namenode='/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg' flags=7 instead='<none>'
            D000020: conffderef in='/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg' result='/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg'
            D000020: tarobject FNNF_NEW_CONFF deref='/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg'
            D000010: path_remove_tree '/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg.dpkg-new'
            D000010: path_remove_tree '/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg.dpkg-tmp'
            D000010: tarobject ti->name='./usr' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/usr' flags=2 instead='<none>'
            D000010: tarobject ti->name='./usr/share' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/usr/share' flags=2 instead='<none>'
            D000010: tarobject ti->name='./usr/share/doc' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/usr/share/doc' flags=2 instead='<none>'
            D000010: tarobject ti->name='./usr/share/doc/zabbix-release' mode=40755 owner=0:0 type=53(d) ti->linkname='' namenode='/usr/share/doc/zabbix-release' flags=2 instead='<none>'
            D000010: tarobject ti->name='./usr/share/doc/zabbix-release/README.Debian' mode=100644 owner=0:0 type=48(-) ti->linkname='' namenode='/usr/share/doc/zabbix-release/README.Debian' flags=2 instead='<none>'
            D000010: path_remove_tree '/usr/share/doc/zabbix-release/README.Debian.dpkg-new'
            D000010: path_remove_tree '/usr/share/doc/zabbix-release/README.Debian.dpkg-tmp'
            D000010: tarobject ti->name='./usr/share/doc/zabbix-release/changelog.Debian' mode=100644 owner=0:0 type=48(-) ti->linkname='' namenode='/usr/share/doc/zabbix-release/changelog.Debian' flags=2 instead='<none>'
            D000010: path_remove_tree '/usr/share/doc/zabbix-release/changelog.Debian.dpkg-new'
            D000010: path_remove_tree '/usr/share/doc/zabbix-release/changelog.Debian.dpkg-tmp'
            D000010: tarobject ti->name='./usr/share/doc/zabbix-release/copyright' mode=100644 owner=0:0 type=48(-) ti->linkname='' namenode='/usr/share/doc/zabbix-release/copyright' flags=2 instead='<none>'
            D000010: path_remove_tree '/usr/share/doc/zabbix-release/copyright.dpkg-new'
            D000010: path_remove_tree '/usr/share/doc/zabbix-release/copyright.dpkg-tmp'
            D000010: deferred extract of '/.'
            D000010: deferred extract of '/etc'
            D000010: deferred extract of '/etc/apt'
            D000010: deferred extract of '/etc/apt/sources.list.d'
            D000010: deferred extract of '/etc/apt/sources.list.d/zabbix-agent2-plugins.list'
            D000010: deferred extract of '/etc/apt/sources.list.d/zabbix.list'
            D000010: deferred extract of '/etc/apt/trusted.gpg.d'
            D000010: deferred extract of '/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg'
            D000010: deferred extract of '/usr'
            D000010: deferred extract of '/usr/share'
            D000010: deferred extract of '/usr/share/doc'
            D000010: deferred extract of '/usr/share/doc/zabbix-release'
            D000010: deferred extract of '/usr/share/doc/zabbix-release/README.Debian'
            D000010: deferred extract of '/usr/share/doc/zabbix-release/changelog.Debian'
            D000010: deferred extract of '/usr/share/doc/zabbix-release/copyright'
            D000002: maintscript_fallback nonexistent postrm '/var/lib/dpkg/info/zabbix-release.postrm'
            D000001: process_archive updating info directory
            D000002: process_archive info installed /var/lib/dpkg/tmp.ci/md5sums as /var/lib/dpkg/info/zabbix-release.md5sums
            D000002: process_archive info installed /var/lib/dpkg/tmp.ci/conffiles as /var/lib/dpkg/info/zabbix-release.conffiles
            D000002: process_archive tmp.ci script/file '.' contains dot
            D000002: process_archive tmp.ci script/file '/var/lib/dpkg/tmp.ci/control' is control
            D000002: process_archive tmp.ci script/file '..' contains dot
            D000001: generating infodb hashfile
            D000010: process_archive looking for overwriting '/etc/apt/sources.list.d/zabbix-agent2-plugins.list'
            D000010: process_archive looking for overwriting '/etc/apt/sources.list.d/zabbix.list'
            D000010: process_archive looking for overwriting '/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg'
            D000010: process_archive looking for overwriting '/usr/share/doc/zabbix-release/README.Debian'
            D000010: process_archive looking for overwriting '/usr/share/doc/zabbix-release/changelog.Debian'
            D000010: process_archive looking for overwriting '/usr/share/doc/zabbix-release/copyright'
            D000010: path_remove_tree '/etc.dpkg-tmp'
            D000010: path_remove_tree '/etc/apt.dpkg-tmp'
            D000010: path_remove_tree '/etc/apt/sources.list.d.dpkg-tmp'
            D000010: path_remove_tree '/etc/apt/trusted.gpg.d.dpkg-tmp'
            D000010: path_remove_tree '/usr.dpkg-tmp'
            D000010: path_remove_tree '/usr/share.dpkg-tmp'
            D000010: path_remove_tree '/usr/share/doc.dpkg-tmp'
            D000010: path_remove_tree '/usr/share/doc/zabbix-release.dpkg-tmp'
            D000010: path_remove_tree running rm -rf '/var/lib/dpkg/tmp.ci'
            D000010: path_remove_tree '/var/lib/dpkg/reassemble.deb'
            D000001: process queue pkg zabbix-release:all queue.len 0 progress 1, try 1
            Setting up zabbix-release (1:6.0-4+debian10) ...
            D000001: deferred_configure updating conffiles
            D000020: deferred_configure '/etc/apt/sources.list.d/zabbix-agent2-plugins.list' (= '/etc/apt/sources.list.d/zabbix-agent2-plugins.list') useredited=1 distedited=0 what=202
            D000020: deferred_configure '/etc/apt/sources.list.d/zabbix.list' (= '/etc/apt/sources.list.d/zabbix.list') useredited=1 distedited=0 what=202
            D000020: deferred_configure '/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg' (= '/etc/apt/trusted.gpg.d/zabbix-official-repo.gpg') useredited=-1 distedited=-1 what=2
            D000002: vmaintscript_installed nonexistent postinst
            After this I'd move it to Debian 12, but maybe I can do the migration and upgrade in one go.
