Another "Zabbix server is not running: the information displayed may not be current"
  • WiVM
    • Nov 2022
    Checked the previous topics on this forum related to this notification in Zabbix, but the suggested settings are already applied.
    The server log at start-up:
     9086:20221122:103352.254 Starting Zabbix Server. Zabbix 4.2.6 (revision d3bb18bbc4).
      9086:20221122:103352.254 ****** Enabled features ******
      9086:20221122:103352.254 SNMP monitoring:           YES
      9086:20221122:103352.254 IPMI monitoring:           YES
      9086:20221122:103352.254 Web monitoring:            YES
      9086:20221122:103352.254 VMware monitoring:         YES
      9086:20221122:103352.254 SMTP authentication:       YES
      9086:20221122:103352.254 Jabber notifications:       NO
      9086:20221122:103352.254 Ez Texting notifications:  YES
      9086:20221122:103352.254 ODBC:                      YES
      9086:20221122:103352.254 SSH2 support:              YES
      9086:20221122:103352.254 IPv6 support:              YES
      9086:20221122:103352.254 TLS support:               YES
      9086:20221122:103352.254 ******************************
      9086:20221122:103352.254 using configuration file: /etc/zabbix/zabbix_server.conf
      9086:20221122:103352.258 current database version (mandatory/optional): 04020000/04020001
      9086:20221122:103352.259 required mandatory version: 04020000
      9086:20221122:103352.650 server #0 started [main process]
      9092:20221122:103352.650 server #1 started [configuration syncer #1]
      9093:20221122:103352.650 server #2 started [housekeeper #1]
      9094:20221122:103352.651 server #3 started [timer #1]
      9095:20221122:103352.651 server #4 started [http poller #1]
      9097:20221122:103352.651 server #5 started [discoverer #1]
      9112:20221122:103352.656 server #19 started [unreachable poller #1]
      9113:20221122:103352.657 server #20 started [trapper #1]
      9114:20221122:103352.659 server #21 started [trapper #2]
      9098:20221122:103352.660 server #6 started [history syncer #1]
      9099:20221122:103352.660 server #7 started [history syncer #2]
      9100:20221122:103352.661 server #8 started [history syncer #3]
      9101:20221122:103352.661 server #9 started [history syncer #4]
      9102:20221122:103352.661 server #10 started [escalator #1]
      9103:20221122:103352.663 server #11 started [proxy poller #1]
      9104:20221122:103352.665 server #12 started [self-monitoring #1]
      9105:20221122:103352.665 server #13 started [task manager #1]
      9106:20221122:103352.665 server #14 started [poller #1]
      9107:20221122:103352.668 server #15 started [poller #2]
      9109:20221122:103352.672 server #16 started [poller #3]
      9115:20221122:103352.674 server #22 started [trapper #3]
      9116:20221122:103352.676 server #23 started [trapper #4]
      9117:20221122:103352.677 server #24 started [trapper #5]
      9110:20221122:103352.677 server #17 started [poller #4]
      9118:20221122:103352.679 server #25 started [icmp pinger #1]
      9120:20221122:103352.679 server #27 started [alerter #1]
      9121:20221122:103352.680 server #28 started [alerter #2]
      9123:20221122:103352.680 server #30 started [preprocessing manager #1]
      9129:20221122:103352.680 server #35 started [lld worker #1]
      9130:20221122:103352.681 server #36 started [lld worker #2]
      9111:20221122:103352.682 server #18 started [poller #5]
      9122:20221122:103352.697 server #29 started [alerter #3]
      9119:20221122:103352.697 server #26 started [alert manager #1]
      9128:20221122:103352.699 server #34 started [lld manager #1]
      9127:20221122:103353.096 server #33 started [preprocessing worker #3]
      9125:20221122:103353.101 server #32 started [preprocessing worker #2]
      9124:20221122:103353.181 server #31 started [preprocessing worker #1]
      9093:20221122:110353.288 executing housekeeper
    No CacheSize error. It is already set to 32M.
    Service is started correctly:
     $ sudo systemctl status zabbix-server
    ● zabbix-server.service - Zabbix Server
       Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
       Active: active (running) since Tue 2022-11-22 10:33:52 CET; 2h 25min ago
      Process: 9079 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=0/SUCCESS)
      Process: 9084 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
     Main PID: 9086 (zabbix_server)
        Tasks: 37
       Memory: 42.6M
       CGroup: /system.slice/zabbix-server.service
               ├─9086 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
               ├─9092 /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.361516 sec, idle 60 sec]
               ├─9093 /usr/sbin/zabbix_server: housekeeper [deleted 42826 hist/trends, 0 items/triggers, 990 events, 0 sessions, 0 alarms, 0 audit items, 0 records in 11.578174 sec, idle for
               ├─9094 /usr/sbin/zabbix_server: timer #1 [updated 0 hosts, suppressed 0 events in 0.001378 sec, idle 59 sec]
               ├─9095 /usr/sbin/zabbix_server: http poller #1 [got 0 values in 0.000465 sec, idle 5 sec]
               ├─9097 /usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.000386 sec, idle 60 sec]
               ├─9098 /usr/sbin/zabbix_server: history syncer #1 [processed 0 values, 33 triggers in 0.000697 sec, idle 1 sec]
               ├─9099 /usr/sbin/zabbix_server: history syncer #2 [processed 0 values, 0 triggers in 0.000025 sec, idle 1 sec]
               ├─9100 /usr/sbin/zabbix_server: history syncer #3 [processed 9 values, 9 triggers in 0.009789 sec, idle 1 sec]
               ├─9101 /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000017 sec, idle 1 sec]
               ├─9102 /usr/sbin/zabbix_server: escalator #1 [processed 0 escalations in 0.000549 sec, idle 3 sec]
               ├─9103 /usr/sbin/zabbix_server: proxy poller #1 [exchanged data with 0 proxies in 0.000021 sec, idle 5 sec]
               ├─9104 /usr/sbin/zabbix_server: self-monitoring [processed data in 0.000018 sec, idle 1 sec]
               ├─9105 /usr/sbin/zabbix_server: task manager [processed 0 task(s) in 0.000413 sec, idle 5 sec]
               ├─9106 /usr/sbin/zabbix_server: poller #1 [got 0 values in 0.000007 sec, idle 1 sec]
               ├─9107 /usr/sbin/zabbix_server: poller #2 [got 2 values in 0.000099 sec, idle 1 sec]
               ├─9109 /usr/sbin/zabbix_server: poller #3 [got 0 values in 0.000016 sec, idle 1 sec]
               ├─9110 /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000016 sec, idle 1 sec]
               ├─9111 /usr/sbin/zabbix_server: poller #5 [got 0 values in 0.000007 sec, idle 1 sec]
               ├─9112 /usr/sbin/zabbix_server: unreachable poller #1 [got 0 values in 0.000020 sec, idle 5 sec]
               ├─9113 /usr/sbin/zabbix_server: trapper #1 [processed data in 0.000034 sec, waiting for connection]
               ├─9114 /usr/sbin/zabbix_server: trapper #2 [processed data in 0.000039 sec, waiting for connection]
               ├─9115 /usr/sbin/zabbix_server: trapper #3 [processed data in 0.000025 sec, waiting for connection]
               ├─9116 /usr/sbin/zabbix_server: trapper #4 [processed data in 0.000025 sec, waiting for connection]
               ├─9117 /usr/sbin/zabbix_server: trapper #5 [processed data in 0.000056 sec, waiting for connection]
               ├─9118 /usr/sbin/zabbix_server: icmp pinger #1 [got 0 values in 0.000019 sec, idle 5 sec]
               ├─9119 /usr/sbin/zabbix_server: alert manager #1 [sent 0, failed 0 alerts, idle 5.006850 sec during 5.006909 sec]
               ├─9120 /usr/sbin/zabbix_server: alerter #1 [sent 0, failed 0 alerts, idle 659.871890 sec during 660.748330 sec]
               ├─9121 /usr/sbin/zabbix_server: alerter #2 [sent 0, failed 0 alerts, idle 660.886616 sec during 661.684920 sec]
               ├─9122 /usr/sbin/zabbix_server: alerter #3 [sent 0, failed 0 alerts, idle 659.931764 sec during 660.714166 sec]
               ├─9123 /usr/sbin/zabbix_server: preprocessing manager #1 [queued 0, processed 53 values, idle 4.999561 sec during 5.000028 sec]
               ├─9124 /usr/sbin/zabbix_server: preprocessing worker #1 started
               ├─9125 /usr/sbin/zabbix_server: preprocessing worker #2 started
               ├─9127 /usr/sbin/zabbix_server: preprocessing worker #3 started
               ├─9128 /usr/sbin/zabbix_server: lld manager #1 [processed 0 LLD rules during 5.004959 sec]
               ├─9129 /usr/sbin/zabbix_server: lld worker #1 [processed 1 LLD rules, idle 3600.212872 sec during 3600.220818 sec]
               └─9130 /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 3600.208454 sec during 3600.220096 sec]
    Nov 22 10:33:52 spappl00112.lnx.*****.** systemd[1]: Starting Zabbix Server...
    Nov 22 10:33:52 spappl00112.lnx.*****.** systemd[1]: Started Zabbix Server.
    SELinux is disabled:
    # This file controls the state of SELinux on the system.
    # SELINUX= can take one of these three values:
    #     enforcing - SELinux security policy is enforced.
    #     permissive - SELinux prints warnings instead of enforcing.
    #     disabled - No SELinux policy is loaded.
    SELINUX=disabled
    # SELINUXTYPE= can take one of three two values:
    #     targeted - Targeted processes are protected,
    #     minimum - Modification of targeted policy. Only selected processes are protected.
    #     mls - Multi Level Security protection.
    SELINUXTYPE=targeted
    The MySQL user/dbname/password are aligned with the Zabbix configuration file /web/zabbix.conf.php and the server config: /zabbix_server.conf
    The used Zabbix version is 4.2.6 on RedHat:
    Static hostname: spappl00112.lnx.*****.**
    Icon name: computer-vm
    Chassis: vm
    Machine ID: 26bbe5104a9b4a96b28ca4720cd58a40
    Boot ID: aae28ed2b79e420d932b5fd6bf6dab56
    Virtualization: vmware
    Operating System: Red Hat Enterprise Linux
    CPE OS Name: cpe:/o:redhat:enterprise_linux:7.9:GA:server
    Kernel: Linux 3.10.0-1160.80.1.el7.x86_64
    Architecture: x86-64
    Server usage:
    • 5004
    Frontend checks directly, is backend is running.. if it cannot do this, it will display that "server not running" warning... so from frontend directly to server:10051 should be possible to connect...
    • WiVM
      • Nov 2022
      This is available and also remains available. The logs are not mentioning anything, so I assume this is some kind of a check to the database or what so ever? Is there a way to check this somewhere? Lower the sensitivity?
