SNMP Interface discovery not discovering all ports
  • christoph-metelcom
    • Oct 2021
    Hi
    SNMP v3 works. I'm using "Template Module Interfaces SNMP​" and tried "Dell Force S-Series SNMP" (it's an DELL N-Switch). The switch has 48 1Gig ports and 4 10Gig (numbers 49-52). Ports 49-52 don't get discovered. Any Idea why discovering for the 10Gig interfaces isn't working?
    IF-MIB::ifType.45 = INTEGER: ethernetCsmacd(6)
    IF-MIB::ifType.46 = INTEGER: ethernetCsmacd(6)
    IF-MIB::ifType.47 = INTEGER: ethernetCsmacd(6)
    IF-MIB::ifType.48 = INTEGER: ethernetCsmacd(6)
    IF-MIB::ifType.49 = INTEGER: ethernetCsmacd(6)
    IF-MIB::ifType.50 = INTEGER: ethernetCsmacd(6)
    IF-MIB::ifType.51 = INTEGER: ethernetCsmacd(6)
    IF-MIB::ifType.52 = INTEGER: ethernetCsmacd(6)​
    IfType is the same for all.
    Christoph​
  • Hamardaban
    • May 2019
    • 2714
    At LLD rule pay attension to filter (https://www.zabbix.com/documentation...scovery#filter)
      • Oct 2021
      Sorry, the problem is not that the interfaces aren't discovered. I can't find them in interface or tag list. If I'm searching for the name (i.e. Te1/0/1) I can see them.
      I also get the values. So far it is working, I was just confused because I can't see them in the interface list
      Christoph​
      • Hamardaban
        • May 2019
        • 2714
        Most likely, interfaces of different types have different IFNAME ( or IFALIAS or IFDESCR).
        Check the regular expressions defined by macros in the screenshot you provided.
