Grouping VMWare discovered items
  • Metalgalle
    • May 2021
    • 14
    Hello Zabbixers!
    I need to find a method to "group" the VMWare discovered items, because I'm monitoring multiple customers with some local-deployed proxies, and the VMWare discovery process creates a lot of confusion...
    It's possibile that multiple customers had the same "Cluster Name" or have some VM with the same name, and so on...
    So, I thought that I can achieve some more "order" prepending a sort of "ID" to every VMWare discovered item, but I failed to do it...
    Another useful task is make all the VMWare discovered items to inherit the "Host Group" from the "father" object linked to the main template (let me say, the vCenter Server).
    Anyone can suggest me how to ho that?
    Thanx a lot in advance to everybody!
  • RocketSam
    • Nov 2025
    Hello Metalgalle, did you manage to find a solution for your task? I have a very similar challenge, but I haven't found a viable workaround yet.
    • Metalgalle
      • May 2021
      • 14
      Hello Sam!
      Unfortunately not...
      At the time I think that the only way to do it is to modify the VMWare Dicoverer code, but I'm not a developer, and so, I don't think that I'm able to do it.
      Anyway, I recently upgraded my server to 7.0, and I not yet tried to check id the new version may have some new features...
      If I'll find a solution, I'll post it!
      • guntis_liepins
        • Oct 2025
        • 58
        I am not exactly sure whatdo you want to achieve, but it seems case for using tags.
        • RocketSam
          • Nov 2025
          Hello guntis. It is an option, but I didn't find a way to use tags for user permissions. I need to limit users' access to the list of host groups, specific dashboards, and possibly other areas. Groups are perfect for it, while with tags, it's not always possible to configure.
