nginx sso asks an authorization
  • sbardeev
    • Nov 2022
    Hi all!
    I was configured an SSO with spnego-http-auth-nginx-module on NGINX, authorization is successful. But web console every new session asks authorization.
    No errors in Windows Security Log. Where in zabbix, nginx or other logs I can see for errors?
  • Markku
    • Sep 2018
    • 1784
    Can you show us a screenshot about the problem? At least I don't have any idea what is an authorization in a browser in this case.
    Markku
    • lisa
      • Aug 2022
      Hello, I have same problem with SSO nginx. In the nginx configuration, I specify a parameter that disables basic web authentication, but it doesn't work. How to disable it in the nginx settings?
      nginx version: 1.18
      My default.conf:
      server {
      access_log /var/log/nginx/zabbix_access.log;
      error_log /var/log/nginx/zabbix_error.log;
      listen 80;
      listen 443 ssl;
      server_name server.zabbix.com;
      ssl_certificate /etc/nginx/ssl/cert.crt;
      ssl_certificate_key /etc/nginx/ssl/key.key;
      if ($scheme != "https") {
      return 301 https://$host$request_uri;
      root /usr/share/zabbix;
      index index.php;
      error_page 401 /index.php?form=default;
      location = /favicon.ico {
      log_not_found off;
      location / {
      auth_basic off;
      allow all;
      try_files $uri $uri/ =404;
      location /assets {
      access_log off;
      expires 10d;
      location ~ /\.ht {
      deny all;
      location ~ /(api\/|conf[^\.]|include|locale) {
      deny all;
      return 404;
      location /vendor {
      deny all;
      return 404;
      location /api_jsonrpc.php {
      allow all;
      location ~ [^/]\.php(/|$) {
      auth_basic off;
      allow all;
      fastcgi_pass unix:/var/run/php/zabbix.sock;
      fastcgi_split_path_info ^(.+\.php)(/.+)$;
      fastcgi_index index.php;
      fastcgi_param DOCUMENT_ROOT /usr/share/zabbix;
      fastcgi_param SCRIPT_FILENAME /usr/share/zabbix$fastcgi_script_name;
      fastcgi_param PATH_TRANSLATED /usr/share/zabbix$fastcgi_script_name;
      include fastcgi_params;
      fastcgi_param QUERY_STRING $query_string;
      fastcgi_param REQUEST_METHOD $request_method;
      fastcgi_param CONTENT_TYPE $content_type;
      fastcgi_param CONTENT_LENGTH $content_length;
      fastcgi_intercept_errors on;
      fastcgi_ignore_client_abort off;
      fastcgi_connect_timeout 60;
      fastcgi_send_timeout 180;
      fastcgi_read_timeout 180;
      fastcgi_buffer_size 128k;
      fastcgi_buffers 4 256k;
      fastcgi_busy_buffers_size 256k;
      fastcgi_temp_file_write_size 256k;
      auth_gss on;
      auth_gss_realm ZABBIX.COM;
      auth_gss_keytab /etc/nginx/auth.keytab;
      auth_gss_service_name HTTP/server.zabbix.com;
      auth_gss_allow_basic_fallback on;
      proxy_set_header Authorization "";
      • lisa
        • Aug 2022
        screenshot with problem
