Database error after upgrading from 6.0 to 6.2.4
  • Stergios
    • Jun 2022
    Upgraded from 6.0 to 6.2.4 on Ubuntu and now getting the error
    "The Zabbix database version does not match current requirements. Your database version: 6010048. Required version: 6020000. Please contact your system administrator."
    Here is the data:
    Linux zabbix 5.4.0-132-generic #148-Ubuntu SMP Mon Oct 17 16:02:06 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
    zabbix_server (Zabbix) 6.2.4
    Revision 885eaefa6f7 2 November 2022​
    /var/log/zabbix/zabbix_server.log
    1102:20221121:063225.069 housekeeper [deleted 99593 hist/trends, 0 items/triggers, 0 events, 1 problems, 0 sessions, 0 alarms,>
    1102:20221121:073225.169 executing housekeeper
    1102:20221121:074115.176 housekeeper [deleted 99568 hist/trends, 0 items/triggers, 0 events, 1 problems, 0 sessions, 0 alarms,>
    1102:20221121:084115.278 executing housekeeper​
    /etc/zabbix/web/zabbix.conf.php
    <?php
    // Zabbix GUI configuration file.
    $DB['TYPE'] = 'MYSQL';
    $DB['SERVER'] = 'localhost';
    $DB['PORT'] = '10051';
    $DB['DATABASE'] = 'zabbix';
    $DB['USER'] = 'zabbix';
    $DB['PASSWORD'] = 'aqualung';
    // Schema name. Used for PostgreSQL.
    $DB['SCHEMA'] = '';
    // Used for TLS connection.
    $DB['ENCRYPTION'] = false;
    $DB['KEY_FILE'] = '';
    $DB['CERT_FILE'] = '';
    $DB['CA_FILE'] = '';
    $DB['VERIFY_HOST'] = false;
    $DB['CIPHER_LIST'] = '';
    // Vault configuration. Used if database credentials are stored in Vault secrets manager.
    $DB['VAULT_URL'] = '';
    $DB['VAULT_DB_PATH'] = '';
    $DB['VAULT_TOKEN'] = '';
    // Use IEEE754 compatible value range for 64-bit Numeric (float) history values.
    // This option is enabled by default for new Zabbix installations.
    // For upgraded installations, please read database upgrade notes before enabling this option.
    $DB['DOUBLE_IEEE754'] = true;
    // Uncomment and set to desired values to override Zabbix hostname/IP and port.
    // $ZBX_SERVER = '';
    // $ZBX_SERVER_PORT = '';
    $ZBX_SERVER_NAME = 'Zabbix';
    $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
    // Uncomment this block only if you are using Elasticsearch.
    // Elasticsearch url (can be string if same url is used for all types).
    //$HISTORY['url'] = [
    // 'uint' => 'http://localhost:9200',
    // 'text' => 'http://localhost:9200'
    // Value types stored in Elasticsearch.
    //$HISTORY['types'] = ['uint', 'text'];
    // Used for SAML authentication.
    // Uncomment to override the default paths to SP private key, SP and IdP X.509 certificates, and to set extra settings.
    //$SSO['SP_KEY'] = 'conf/certs/sp.key';
    //$SSO['SP_CERT'] = 'conf/certs/sp.crt';
    //$SSO['IDP_CERT'] = 'conf/certs/idp.crt';
    //$SSO['SETTINGS'] = [];
    ​any help would be much appreciated
    • 4996
    That error is from GUI? You should first (re?)start your server, let it do the upgrade tasks and only after that connect to GUI.
    • Stergios
      • Jun 2022
      Yes, the error comes from GUI
      I restarted the zabbix server and rebooted the whole Ubuntu Sever
      Upgrade is finished, unfortunately something went wrong during the procedure...
