How to change Zabbix Database
  • target
    • Nov 2022
    • 21
    Hello All,
    I am trying to change the database to Zabbix 6.2. Basically I have copied an old mysql database from another Zabbix and need to load it on a new Zabbix server. Is it possible?
    Best Regards,
  • Answer selected by target at 29-11-2022, 12:58.
    Markku
    • Sep 2018
    • 1784
    Yes, see for example https://majornetwork.net/2022/01/mov...bbix-database/
    The steps in brief:
    - Dump the database on the old server: mysqldump --single-transaction zabbix | gzip > /mnt/zbx-dump.sql.gz
    - Copy the file to the new server
    - Create the new empty database on the new server and create the zabbix database user (see Zabbix installation documentation for details if needed)
    - Load the database: zcat zbx-dump.sql.gz | mysql -u zabbix -p zabbix
    When starting the new Zabbix server with the new database it will automatically update the database to the new schema, see zabbix_server.log for any errors.
    (Disclaimer: the commands above were tested with MariaDB 10.1.x and 10.5.x, in MySQL the command defaults may be different, I don't know.)
    Markku
    • Markku
      • Sep 2018
      • 1784
      The steps in brief:
      Markku
