Too high configuration cache
  • f0rslund
    • Nov 2022
    Hello!
    I have problem figuring out what's causing the Zabbix server to report the problem: More than 75% used in the configuration cache.
    I have tried to Google the problem and also found a solution to change the value of CacheSize in zabbix_server.conf from the standard 32M to a higher. So i tried to up the value to 256M and then restarted the service, but the graph only shows that the Value Cache is affected by this change.
    The attached image clearly shows that the change only affects Value Cache and not Configuration Cache..
    Is there any other way to fix this?
    Thanks!
  • Markku
    • Sep 2018
    • 1786
    Works here (increased CacheSize from the default 32M to 64M, configuration cache utilization dropped from 36% to 18%):
    Click image for larger version  Name:	image.png Views:	0 Size:	497.3 KB ID:	454986​
    $ sudo grep ^CacheSize /etc/zabbix/zabbix_server.conf
    CacheSize=64M
    Zabbix 6.2.4 and the default "Zabbix server health" template. (The graph title is incorrect when saying "% free", it is "% used" as shown in the legend)
    Markku
