Sending failed: Invalid MS Teams webhook URL
  • msvmg
    • Nov 2022
    Hi.
    I have Zabbix 6.2.4
    I have problem with webhook Zabbix to MS Teams. I checked the forum for answer but i cant find right one.
    Maybe someone has the same problem and any answer from forum didnt work?
    Or maybe this is the problem of Zabbix Version
  • Answer selected by msvmg at 05-12-2022, 14:10.
    Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    Chances you have an old media type left from previous versions.
    Please see https://support.zabbix.com/browse/ZBX-19488 and update your media type.
    • Glencoe
      Zabbix developer
      • Oct 2019
      • 153
      • msvmg
        • Nov 2022
        Yes, this is the answer! thank you.
        One more quick question cause i got to set parameter "Event Source" i can put there numbers 0-4 what is difference between those numbers?
      • msvmg
        • Nov 2022
        Thank you!
