blank page after setup
  • pischta
    • Nov 2022
    I installed Zabbix 6.2 on Debian Bookworm with mariadb. I went through the setup steps. At the end I got a message about that it cannot write the zabbix.conf.php​, so I downloaded it and copied it to /etc/zabbix/​. After that the next (finish?) button didn't work. I visited the main page, but I got blank page. I restarted the server, but I still see only blank page.
    From the apache2 log:
    [Tue Nov 29 15:10:52.704043 2022] [php:warn] [pid 733] [client 172.17.100.101:60339] PHP Warning: Undefined array key 0 in /usr/share/zabbix/include/classes/api/services/CAuthentication.php on line 75
    [Tue Nov 29 15:10:52.704103 2022] [php:error] [pid 733] [client 172.17.100.101:60339] PHP Fatal error: Uncaught TypeError: CAuthentication::get(): Return value must be of type array, null returned in /usr/share/zabbix/include/classes/api/services/CAuthentication.php:75\nStack trace:\n#0 /usr/share/zabbix/include/classes/helpers/CAuthenticationHelper.php(72): CAuthentication->get()\n#1 /usr/share/zabbix/include/classes/helpers/CConfigGeneralHelper.php(47): CAuthenticationHelper::loadParams()\n#2 /usr/share/zabbix/include/classes/api/services/CUser.php(1498): CConfigGeneralHelper::get()\n#3 /usr/share/zabbix/include/classes/api/clients/CLocalApiClient.php(121): CUser->login()\n#4 /usr/share/zabbix/include/classes/api/wrappers/CFrontendApiWrapper.php(97): CLocalApiClient->callMethod()\n#5 /usr/share/zabbix/include/classes/api/wrappers/CApiWrapper.php(94): CFrontendApiWrapper->callClientMethod()\n#6 /usr/share/zabbix/include/classes/api/wrappers/CFrontendApiWrapper.php(63): CApiWrapper->callMethod()\n#7 /usr/share/zabbix/include/classes/api/wrappers/CApiWrapper.php(82): CFrontendApiWrapper->callMethod()\n#8 /usr/share/zabbix/include/classes/user/CWebUser.php(105): CApiWrapper->__call()\n#9 /usr/share/zabbix/include/classes/core/ZBase.php(464): CWebUser::checkAuthentication()\n#10 /usr/share/zabbix/include/classes/core/ZBase.php(187): ZBase->authenticateUser()\n#11 /usr/share/zabbix/include/config.inc.php(25): ZBase->run()\n#12 /usr/share/zabbix/index.php(24): require_once('...')\n#13 {main}\n thrown in /usr/share/zabbix/include/classes/api/services/CAuthentication.php on line 75
    From the server log:
    812:20221129:151716.825 [Z3005] query failed: [1054] Unknown column 'lastaccess' in 'field list' [select hostid,proxy_hostid,host,ipmi_authtype,ipmi_privil ege,ipmi_username,ipmi_password,maintenance_status ,maintenance_type,maintenance_from,status,name,las taccess,tls_connect,tls_accept,tls_issuer,tls_subj ect,tls_psk_identity,tls_psk,proxy_address,auto_co mpress,maintenanceid from hosts where status in (0,1,5,6) and flags<>2]
    zabbix_server [812]: ERROR [file and function: <dbconfig.c,DCsync_configuration>, revision:e35d7dceead, line:6687] Something impossible has just happened.
    812:20221129:151716.825 === Backtrace: ===
    812:20221129:151716.825 9: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](zbx_backtrace+0x4d) [0x55c9dd4afdbd]
    812:20221129:151716.825 8: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](DCsync_configuration+0x1276) [0x55c9dd457e46]
    812:20221129:151716.825 7: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](dbconfig_thread+0x2b7) [0x55c9dd3462a7]
    812:20221129:151716.825 6: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](zbx_thread_start+0x20) [0x55c9dd4bbb00]
    812:20221129:151716.825 5: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](+0x7383b) [0x55c9dd33883b]
    812:20221129:151716.825 4: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](MAIN_ZABBIX_ENTRY+0x963) [0x55c9dd3398f3]
    812:20221129:151716.825 3: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](main+0x552) [0x55c9dd330822]
    812:20221129:151716.826 2: /lib/x86_64-linux-gnu/libc.so.6(+0x2718a) [0x7fa64990c18a]
    812:20221129:151716.826 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7fa64990c245]
    812:20221129:151716.826 0: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.011623 sec, syncing configuration](_start+0x21) [0x55c9dd337b41]​
  • pischta
    • Nov 2022
    I restarted the installation on Debian Bullseye. It works flawlessly...
