Very new to Zabbix, currently installed and setup Zabbix server and agent on 2 VMs for testing. I have been able to do the setup and login to the dashboard. I have added the agent host to the dashboard and its availability status is stuck at unknown. I found online that it would become available once the 3 tests (Detect Operating System, Ping and Traceroute would work). I managed to make ping and traceroute work by installing nmap, traceroute and enabling their use by zabbix in selinux policies. However, I'm not able to make 'Detect Operating System' work.
I get the following error when I run it:
I have added `zabbix ALL=(ALL) NOPASSWD: ALL` to visudo and don't see any logs in /var/log/audit/audit.log so I don't think selinux is stopping the execution. I can run the command
with my local user in zabbix server. But I cannot use the zabbix user. I get the following error when I try it:
System Information: Rocky Linux 8.6
DB: Postgresql 13
Zabbix: 6.0
Please help with this issue and let me know what further info I need to provide regarding this.
Thanks,
Cannot execute script.
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
sudo nmap -O <agent_IP>
sudo su - zabbix
su: warning: cannot change directory to /var/lib/zabbix: No such file or directory
This account is currently not available.
DB: Postgresql 13
Zabbix: 6.0
Thanks,
