zabbix trigger never update even when trigger condition is not valid anymore
  • ghislain
    • Jun 2005
    • 160
    hi there
    Since i upgraded to zabbix 6 i have issue with triggers and alerts that are on a long time range. For exemple i monitor mdadm raid event with:
    nodata(/thehost.com/mdadmevent,86400)=0
    i tried to change also to
    count(/thehost.com/mdadmevent,86400)>0
    but the alert saty event with last data in this item is:
    2022-12-04 09:59:24 RebuildFinished /dev/md/part03 mismatches found: 169984 (on raid level 10)
    we are the 5th decembre at 15H22 and the alert is still here.
    this is all the servers with this trigger that are affected. I have several other trigger that had the same issue. This server is an old one from v4 that has been upgraded regulary until now at 6.2.
    logs show no errors
    HTML Code:
    1024:20221205:152801.975 Zabbix Server stopped. Zabbix 6.2.4 (revision 885eaefa6f7).
    3363782:20221205:152802.003 Starting Zabbix Server. Zabbix 6.2.4 (revision 885eaefa6f7).
    3363782:20221205:152802.003 ****** Enabled features ******
    3363782:20221205:152802.003 SNMP monitoring: YES
    3363782:20221205:152802.003 IPMI monitoring: YES
    3363782:20221205:152802.003 Web monitoring: YES
    3363782:20221205:152802.003 VMware monitoring: YES
    3363782:20221205:152802.003 SMTP authentication: YES
    3363782:20221205:152802.003 ODBC: YES
    3363782:20221205:152802.003 SSH support: YES
    3363782:20221205:152802.003 IPv6 support: YES
    3363782:20221205:152802.003 TLS support: YES
    3363782:20221205:152802.003 ******************************
    3363782:20221205:152802.003 using configuration file: /etc/zabbix/zabbix_server.conf
    3363782:20221205:152802.021 current database version (mandatory/optional): 06020000/06020003
    3363782:20221205:152802.021 required mandatory version: 06020000
    Any ideas of what is causing the issue ?
    best regards,
    Ghislain.
    Regards,
    Ghislain.
  • ghislain
    • Jun 2005
    • 160
    title is abusing it is not ever, it is ever for trigger with long tiem range, the others seems to work fine.
    Regards,
    Ghislain.
