Upgrade failed from 6.0.11 to 6.0.12
  • SupportMD
    • Dec 2022
    I am on Debian buster/sid with mysql 5.7.40
    I have upgraded Zabbix from 6.0.11 to 6.0.12 this morning but the service doesn't start.
    This is the log :
    26427:20221206:164348.598 database upgrade failed
    26448:20221206:164400.799 Starting Zabbix Server. Zabbix 6.0.12 (revision 126aa2f53e9).
    26448:20221206:164400.799 ****** Enabled features ******
    26448:20221206:164400.799 SNMP monitoring: YES
    26448:20221206:164400.799 IPMI monitoring: YES
    26448:20221206:164400.799 Web monitoring: YES
    26448:20221206:164400.799 VMware monitoring: YES
    26448:20221206:164400.799 SMTP authentication: YES
    26448:20221206:164400.799 ODBC: YES
    26448:20221206:164400.799 SSH support: YES
    26448:20221206:164400.799 IPv6 support: YES
    26448:20221206:164400.799 TLS support: YES
    26448:20221206:164400.799 ******************************
    26448:20221206:164400.799 using configuration file: /etc/zabbix/zabbix_server.conf
    26448:20221206:164400.840 current database version (mandatory/optional): 06000000/06000010
    26448:20221206:164400.840 required mandatory version: 06000000
    26448:20221206:164400.840 optional patches were found
    26448:20221206:164400.840 starting automatic database upgrade
    26448:20221206:164400.841 [Z3005] query failed: [1419] You do not have the SUPER privilege and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable) [create trigger hosts_name_upper_insert
    before insert on hosts for each row
    set new.name_upper=upper(new.name)]
    I have set GLOBAL log_bin_trust_function_creators = 1;​​ without effect.
    Can you please help me to resolve ?
  • Markku
    • Sep 2018
    • 1784
    Note that your MySQL version 5.7.40 is not supported in Zabbix 6.0: https://www.zabbix.com/documentation...n/requirements
    Maybe that is the reason for the problem?
    (Also, Debian Buster ("oldstable") is different from Debian Sid ("unstable") so your setup sounds quite strange)
    Markku
