Zabbix agent for RHEL8.4 on PPC64LE supported?
  • troyski
    • Mar 2021
    Hi all,
    We've just started rolling out some RHEL8 servers on our Power platform (PPC64LE), however when compiling the agent I'm getting:
    checking for the linux kernel version... unknown family (4.18.0-305.25.1.el8_4.ppc64le)
    checking size of void *... 8
    configure: using old pcre library by default
    checking for pkg-config... /usr/bin/pkg-config
    checking pkg-config is at least version 0.9.0... yes
    configure: error: cannot find pkg-config package for libpcre​
    ..does this mean my kernel is not yet supported by the Zabbix sources?
    I've tried zabbix-5.0.30.tar.gz and zabbix-6.0.12.tar.gz with the same result.
    Thanks in advance for any pointers?
    Troyski
  • Answer selected by troyski at 12-12-2022, 18:14.
    tim.mooney
    • Dec 2012
    • 1430
    No, it's only warning about the unknown kernel family. That's a combination that probably hasn't been tested much.
    The error is from the line that says "error". You're missing .pc file related to your libpcre, which probably means you don't have some devel package installed (either pcre-devel or pcre2-devel, depending on which PCRE you want to link with).
    • troyski
      troyski commented
      Thanks Tim, I'll go look at that.
  • tim.mooney
    • Dec 2012
    • 1430
    • troyski
      troyski commented
  • iamjahid
    • Dec 2022
    Need to Help to deploy Distributed Zabbix in Ubuntu 22.04 LTS
