Zabbix Server Not Running
  • akeccs
    • Dec 2022
    I setup a Zabbix server as a VM in Vmware 6.7. After adding quite a of our switches to Zabbix the server no longer starts. Looking at the logs it states I need to increase my cache size limit, which I have done, now to 15GB, which seems excessive, however it still fails to start, I am not that knowledgeable on Linux so I am learning as I go.
    I have attached the config to this post, if anyone can help it would be much appreciated.
    2008:20221209:131504.601 ================================
      2008:20221209:131504.601 === Backtrace: ===
      2008:20221209:131504.602 16: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x5614e750ae24]
      2008:20221209:131504.602 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_shmem_realloc+0xe8) [0x5614e75060d1]
      2008:20221209:131504.602 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1f7f46) [0x5614e7487f46]
      2008:20221209:131504.602 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_reserve+0xc1) [0x5614e750dfd0]
      2008:20221209:131504.602 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert_ext+0xec) [0x5614e750e245]
      2008:20221209:131504.602 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert+0x2d) [0x5614e750e157]
      2008:20221209:131504.602 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCfind_id+0x86) [0x5614e748880a]
      2008:20221209:131504.602 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x202c92) [0x5614e7492c92]
      2008:20221209:131504.602 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x12bc) [0x5614e7495a38]
      2008:20221209:131504.602 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x14f) [0x5614e7313872]
      2008:20221209:131504.602 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x5614e7517941]
      2008:20221209:131504.602 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x7197e) [0x5614e730197e]
      2008:20221209:131504.602 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x83e) [0x5614e7302b9a]
      2008:20221209:131504.602 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_daemon_start+0x3b1) [0x5614e750aa3a]
      2008:20221209:131504.602 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x36b) [0x5614e730121e]
      2008:20221209:131504.602 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7effeb49bcf3]
      2008:20221209:131504.602 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x5614e72ffd8e]
      2008:20221209:131504.602 [file:dbconfig.c,line:97] __zbx_shmem_realloc(): out of memory (requested 366104 bytes)
      2008:20221209:131504.602 [file:dbconfig.c,line:97] __zbx_shmem_realloc(): please increase CacheSize configuration parameter
      2005:20221209:131504.605 One child process died (PID:2008,exitcode/signal:1). Exiting ...
      2006:20221209:131505.094 HA manager has been paused
      2006:20221209:131505.098 HA manager has been stopped
      2005:20221209:131505.099 Zabbix Server stopped. Zabbix 6.2.3 (revision 98ee88fc19d).
      2014:20221209:131515.326 Starting Zabbix Server. Zabbix 6.2.3 (revision 98ee88fc19d).
      2014:20221209:131515.326 ****** Enabled features ******
      2014:20221209:131515.326 SNMP monitoring:           YES
      2014:20221209:131515.326 IPMI monitoring:           YES
      2014:20221209:131515.326 Web monitoring:            YES
      2014:20221209:131515.326 VMware monitoring:         YES
      2014:20221209:131515.326 SMTP authentication:       YES
      2014:20221209:131515.326 ODBC:                      YES
      2014:20221209:131515.326 SSH support:               YES
      2014:20221209:131515.326 IPv6 support:              YES
      2014:20221209:131515.326 TLS support:               YES
      2014:20221209:131515.326 ******************************
      2014:20221209:131515.326 using configuration file: /etc/zabbix/zabbix_server.conf
      2014:20221209:131515.336 current database version (mandatory/optional): 06020000/06020002
      2014:20221209:131515.336 required mandatory version: 06020000
      2015:20221209:131515.341 starting HA manager
      2015:20221209:131515.344 HA manager started in active mode
      2014:20221209:131515.344 server #0 started [main process]
      2016:20221209:131515.345 server #1 started [service manager #1]
      2017:20221209:131515.345 server #2 started [configuration syncer #1]
      2017:20221209:131515.842 __mem_malloc: skipped 10 asked 366104 skip_min 568 skip_max 246680
      2017:20221209:131515.842 === memory statistics for configuration cache ===
      2017:20221209:131515.842 free chunks of size >= 256 bytes:       10
      2017:20221209:131515.842 min chunk size:        568 bytes
      2017:20221209:131515.842 max chunk size:     246680 bytes
      2017:20221209:131515.842 memory of total size 29195520 bytes fragmented into 272409 chunks
      2017:20221209:131515.843 of those,     369896 bytes are in       10 free chunks
      2017:20221209:131515.843 of those,   28825624 bytes are in   272399 used chunks
      2017:20221209:131515.843 of those,    4358528 bytes are used by allocation overhead
      2017:20221209:131515.843 ================================
      2017:20221209:131515.843 === Backtrace: ===
      2017:20221209:131515.844 16: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x556ca3769e24]
      2017:20221209:131515.844 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_shmem_realloc+0xe8) [0x556ca37650d1]
      2017:20221209:131515.844 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1f7f46) [0x556ca36e6f46]
      2017:20221209:131515.844 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_reserve+0xc1) [0x556ca376cfd0]
      2017:20221209:131515.844 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert_ext+0xec) [0x556ca376d245]
      2017:20221209:131515.844 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert+0x2d) [0x556ca376d157]
      2017:20221209:131515.844 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCfind_id+0x86) [0x556ca36e780a]
      2017:20221209:131515.844 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x202c92) [0x556ca36f1c92]
      2017:20221209:131515.844 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x12bc) [0x556ca36f4a38]
      2017:20221209:131515.844 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x14f) [0x556ca3572872]
      2017:20221209:131515.844 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x556ca3776941]
      2017:20221209:131515.844 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x7197e) [0x556ca356097e]
      2017:20221209:131515.844 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x83e) [0x556ca3561b9a]
      2017:20221209:131515.844 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_daemon_start+0x3b1) [0x556ca3769a3a]
      2017:20221209:131515.844 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x36b) [0x556ca356021e]
      2017:20221209:131515.844 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f8d4f317cf3]
      2017:20221209:131515.844 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x556ca355ed8e]
      2017:20221209:131515.844 [file:dbconfig.c,line:97] __zbx_shmem_realloc(): out of memory (requested 366104 bytes)
      2017:20221209:131515.844 [file:dbconfig.c,line:97] __zbx_shmem_realloc(): please increase CacheSize configuration parameter
      2014:20221209:131515.847 One child process died (PID:2017,exitcode/signal:1). Exiting ...
      2015:20221209:131515.847 HA manager has been paused
      2015:20221209:131515.851 HA manager has been stopped
      2014:20221209:131515.852 Zabbix Server stopped. Zabbix 6.2.3 (revision 98ee88fc19d)​
  • Markku
    • Sep 2018
    • 1784
    You need to remove the comment character (#) from the CacheSize line:
    # CacheSize=15G
    and make it smaller again, like 128M or whatever is suitable.
    Markku
    • Markku
      • Sep 2018
      • 1784
      Make sure that your Zabbix server host in the GUI has a Zabbix server template attached, then you will get graphs and alerts about the various cache utilizations in the long run.
      Also, you may need to consider changing the database user password now that you sent it to the internet.
      Markku
      • akeccs
        • Dec 2022
        I have removed the comment character and setting to 2G, still no go:
        211113:20221212:093909.838 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x55a7ab2ecd8e]
        211113:20221212:093909.838 [file:dbconfig.c,line:97] __zbx_shmem_realloc(): out of memory (requested 366104 bytes)
        211113:20221212:093909.838 [file:dbconfig.c,line:97] __zbx_shmem_realloc(): please increase CacheSize configuration parameter
        211110:20221212:093909.843 One child process died (PID:211113,exitcode/signal:1). Exiting ...
        211111:20221212:093909.843 HA manager has been paused
        211111:20221212:093909.846 HA manager has been stopped
        211110:20221212:093909.848 Zabbix Server stopped. Zabbix 6.2.3 (revision 98ee88fc19d).
        211119:20221212:093920.076 Starting Zabbix Server. Zabbix 6.2.3 (revision 98ee88fc19d).
        211119:20221212:093920.076 ****** Enabled features ******
        211119:20221212:093920.076 SNMP monitoring:           YES
        211119:20221212:093920.076 IPMI monitoring:           YES
        211119:20221212:093920.076 Web monitoring:            YES
        211119:20221212:093920.076 VMware monitoring:         YES
        211119:20221212:093920.076 SMTP authentication:       YES
        211119:20221212:093920.076 ODBC:                      YES
        211119:20221212:093920.076 SSH support:               YES
        211119:20221212:093920.076 IPv6 support:              YES
        211119:20221212:093920.076 TLS support:               YES
        211119:20221212:093920.076 ******************************
        211119:20221212:093920.076 using configuration file: /etc/zabbix/zabbix_server.conf
        211119:20221212:093920.086 current database version (mandatory/optional): 06020000/06020002
        211119:20221212:093920.086 required mandatory version: 06020000
        211120:20221212:093920.092 starting HA manager
        211120:20221212:093920.094 HA manager started in active mode
        211119:20221212:093920.094 server #0 started [main process]
        211121:20221212:093920.095 server #1 started [service manager #1]
        211122:20221212:093920.095 server #2 started [configuration syncer #1]
        211122:20221212:093920.576 __mem_malloc: skipped 10 asked 366104 skip_min 568 skip_max 246680
        211122:20221212:093920.577 === memory statistics for configuration cache ===
        211122:20221212:093920.577 free chunks of size >= 256 bytes:       10
        211122:20221212:093920.577 min chunk size:        568 bytes
        211122:20221212:093920.577 max chunk size:     246680 bytes
        211122:20221212:093920.577 memory of total size 29195520 bytes fragmented into 272409 chunks
        211122:20221212:093920.577 of those,     369896 bytes are in       10 free chunks
        211122:20221212:093920.577 of those,   28825624 bytes are in   272399 used chunks
        211122:20221212:093920.577 of those,    4358528 bytes are used by allocation overhead
        211122:20221212:093920.577 ================================
          • 4996
          if 2G did not work, go up to 4. If that fails, go up to 8...
          • akeccs
            • Dec 2022
            Currently at 18G, guess I'll keep going up.
            • akeccs
              • Dec 2022
              Had to increase the size of the disk on the VM to go any higher, now getting a different error:
              1489:20221212:124903.484 using configuration file: /etc/zabbix/zabbix_server.conf
                1489:20221212:124903.494 current database version (mandatory/optional): 06020000/06020002
                1489:20221212:124903.494 required mandatory version: 06020000
                1490:20221212:124903.500 starting HA manager
                1490:20221212:124903.503 HA manager started in active mode
                1489:20221212:124903.503 cannot initialize configuration cache: cannot get private shared memory of size 25769803776 for configuration cache: [12] Cannot allocate memory
                1490:20221212:124903.503 HA manager has been paused
                1490:20221212:124903.506 HA manager has been stopped
                1489:20221212:124903.507 Zabbix Server stopped. Zabbix 6.2.3 (revision 98ee88fc19d).
                1495:20221212:124915.733 Starting Zabbix Server. Zabbix 6.2.3 (revision 98ee88fc19d).
                1495:20221212:124915.733 ****** Enabled features ******
                1495:20221212:124915.733 SNMP monitoring:           YES
                1495:20221212:124915.734 IPMI monitoring:           YES
                1495:20221212:124915.734 Web monitoring:            YES
                1495:20221212:124915.734 VMware monitoring:         YES
                1495:20221212:124915.734 SMTP authentication:       YES
                1495:20221212:124915.734 ODBC:                      YES
                1495:20221212:124915.734 SSH support:               YES
                1495:20221212:124915.734 IPv6 support:              YES
                1495:20221212:124915.734 TLS support:               YES
                1495:20221212:124915.734 ******************************
              Also tried changing this to 25769803776 didn't work, after reboot reverted:
              [root@appliance zabbix]# sysctl -a |grep shmmax
              kernel.shmmax = 18446744073692774399
              • Markku
                • Sep 2018
                • 1784
                That's not 2G, that's 32M (the default in 6.2) right there.
                Please send these outputs:
                sudo grep CacheSize /etc/zabbix/zabbix_server.conf
                sudo grep Include /etc/zabbix/zabbix_server.conf
                Markku
                • akeccs
                  • Dec 2022
                  [root@appliance zabbix]# sudo grep CacheSize /etc/zabbix/zabbix_server.conf
                  ### Option: VMwareCacheSize
                  # VMwareCacheSize=1G
                  ### Option: CacheSize
                  CacheSize=24G
                  ### Option: HistoryCacheSize
                  # HistoryCacheSize=32M
                  ### Option: HistoryIndexCacheSize
                  # HistoryIndexCacheSize=512M
                  ### Option: TrendCacheSize
                  # TrendCacheSize=8M
                  ### Option: TrendFunctionCacheSize
                  # TrendFunctionCacheSize=8M
                  ### Option: ValueCacheSize
                  # ValueCacheSize=400M
                  [root@appliance zabbix]# sudo grep Include /etc/zabbix/zabbix_server.conf
                  ### Option: Include
                  # Include=
                  # Include=/usr/local/etc/zabbix_server.general.conf
                  # Include=/usr/local/etc/zabbix_server.conf.d/
                  # Include=/usr/local/etc/zabbix_server.conf.d/*.conf
                  • Markku
                    • Sep 2018
                    • 1784
                    How about testing again with some sensible CacheSize value like 1G so that we eliminate huge memory allocation problems.
                    Then show the error log again.
                    In my tests the "memory of total size" output (that I quoted earlier) correlated directly with the CacheSize value.
                    root@appliance
                    If this is the Zabbix appliance, I don't know if it works somehow different. Anyone?
                    Markku
                    • Markku
                      • Sep 2018
                      • 1784
                      Also, you are not running the latest 6.2.x release so upgrading it would eliminate any issues that have been fixed after 6.2.3.
                      Markku
                      • akeccs
                        • Dec 2022
                        Ok, I feel like I am loosing my mind, I now just set it back to 1G and rebooted the server, all seems to be working....
                        • Markku
                          • Sep 2018
                          • 1784
                          Great, just remember to apply the Zabbix server template (if it not assigned yet) so that you get metrics for these cache utilizations, they are very useful.
                          Markku
                          • akeccs
                            • Dec 2022
                            Yes I have applied the template. Thank you for your time, much appreciated.
