cannot import schema data
  • diego527
    • Dec 2022
    Whenever I try to import the schema and initial data shows me this error so I get stuck on it
  • Markku
    • Sep 2018
    • 1784
    See the instructions: https://www.zabbix.com/download?zabb...ysql&ws=apache
    set global log_bin_trust_function_creators = 1;
    Also, say
    drop database zabbix;
    in the mysql prompt after that to delete the incomplete database that was created in your process. Then import the schema again with the zcat thing.
    Edit: actually start with dropping the database and then create the database and set the log_bin_trust_function_creators etc just like instructed.
    Markku
    • diego527
      diego527 commented
      Thank you it worked!
      But I have another question, I accidentally executed the same commands again, those here:
      # wget https://repo.zabbix.com/zabbix/6.0/u...u22.04_all.deb
      # dpkg -i zabbix-release_6.0-4+ubuntu22.04_all.deb
      # apt update
      # apt install zabbix-server-mysql zabbix-frontend-php zabbix-apache-conf zabbix-sql-scripts zabbix-agent
      Could it change something from the original installation?
  • Markku
    • Sep 2018
    • 1784
    No, that's fine, installing the same packages again doesn't really do anything. If there happened to be new versions released meanwhile, then it would just upgrade the packages in-place.
    Markku
    • diego527
      • Dec 2022
      Thank you, it worked!
