Zabbix Agent2 SMART monitoring on Win workstations -JSON Go error
  • avial
    • Dec 2022
    Hi all! I try to setup SMART monitoring on number of Windows computers in my organisation, and discovery of disks and request with key `smart.disks.get` just returns good JSON with all info, but after that requests about new information on discovered disks such a
    HTML Code:
     zabbix_get -s some-ip -p 10050 -k 'smart.disk.get[/dev/sda,""]'
    fails with error ZBX_NOTSUPPORTED: Cannot fetch data: Cannot unmarshal JSON: json: cannot unmarshal number 2285107743303 into Go struct field rawField.ata_smart_attributes.table.raw.value of type int.
    it is possible to find some workaround ti this?
    default "SMART by Zabbix Agent 2" template
    zabbix server: 6.0.9
    zabbix_agent2: 6.0.9
    smartmintools: 7.0.1-1
  • avial
    • Dec 2022
    oh, i find it. zabbix agent must be same architecture as monitored host
    • LeapAmol
      • Feb 2023
      Well, I got an issue while using SMART with agent2.
      SMART [sda cciss,0]: Some command to the disk failed​
      please help me to fix this.
      • LeapAmol
        • Feb 2023
        Here are the errors ​
