Service Desk Plus webhook
  • wmckay85
    • Dec 2022
    Hello, I'm working through the steps from the documentation and I'm stuck.
    I get an HTTP 500 error on testing my webhook.
    I have done all the steps below, including making a Zabbix user in both environments with the same username and password. I'm using the technician key from my own SD+ account since they charge for the technician licenses.
    Setting up the on-premise installation
    1. Go to Admin -> Technicians.
    2. Click the Add New Technician link, enter the Technician details and provide login permission.
    3. Click Generate link under the API key details block. Select a time frame for the key to expire using the Calendar icon, or simply retain the same key perpetually.
    4. Save TEHNICAN_KEY for use in Zabbix later.
    Once this is done I will do this part in Zabbix:
    Setting up the webhook in Zabbix
    1. In the Administration > Media types section, import media_manageengine_servicedesk.yaml.
    2. Open the newly added ManageEngine ServiceDesk media type and replace all <PLACEHOLDERS> with your values.
    The following parameters are required for on-premise ServiceDesk:
    sd_on_premise - true.
    sd_url - the URL of your instance.
    sd_on_premise_auth_token - the TEHNICAN_KEY generated earlier.
    field_ref:requester - login of the account used for request creation.
