Zabbix agent rpm package signature and RHEL 9
  • svb
    • Nov 2022
    when installing Zabbix agent on RHEL 9 system, error is displayed regarding rpm package signature:
    Zabbix 6.2 RHEL 9 x86_64 12 kB/s | 1.7 kB 00:00
    Importing GPG key 0xA14FE591:
    Userid : "Zabbix LLC <[email protected]>"
    Fingerprint: A184 8F53 52D0 22B9 471D 83D0 082A B56B A14F E591
    warning: Signature not supported. Hash algorithm SHA1 not available.
    Key import failed (code 2). Failing package is: zabbix-agent2-6.2.4-release1.el9.x86_64
    Red Hat documentation [1] states that SHA1 has been deprecated in RHEL 9. The document also shows a workaround for this problem.
    If workaround is not enough, then Zabbix should sign packages with some other, modern algorithm?
    [1] https://www.redhat.com/en/blog/rhel-...trusted-rhel-9
    svb
  • tim.mooney
    • Dec 2012
    • 1436
    Good info. If you would be willing to take an extra step, please consider reporting this to via the free bug tracker at https://support.zabbix.com/
    This is the kind of thing the developer's should definitely act upon.
    • svb
      • Nov 2022
      OK, thanks for the tip. Created ticket https://support.zabbix.com/browse/ZBX-22107
